Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > RC4WD Bully
Thread: 2.2 bully axles
Old 04-26-2011, 11:01 AM   #1
Wink 2.2 bully axles
I am currently building a custom 1/10 crawler with bully axles and I am new at the hobby still. I am looking for ideas on what wheels I can use for these axles. Any help would be appreciated.
magman is offline   Reply With Quote
Old 04-26-2011, 11:19 AM   #2
Any wheel with a 12mm hex should fit the bill.
JeremyH is offline   Reply With Quote
Old 04-26-2011, 02:04 PM   #3
I'm using the proline eight shooters with rc4wd hub extenders on the front and just the eight shooters on the rear. They are cheap and narrow. Not real excited about the small short screws that come with them for the bead locks. Looks like they will strip easy. They are the axial offset. The extenders get the tires away from the shocks and links. Also adds some stability.
josh6575 is offline   Reply With Quote
Old 04-26-2011, 06:13 PM   #4
Hey Jeremy, this is my buddy i've been trying to get to bring his ax to the comps with me. I'm helping him build a 2.2 moa comp crawler. I want to go a little narrower than usual on the wheels for his truck. Gonna use PD rovers but was wondering if you had any suggestions on a slightly narrowed wheel other than VP?
JSSOUTHTX is offline   Reply With Quote
Old 04-26-2011, 08:03 PM   #5
Jason, when I ran my Bully, I stuck with wheels that were in the Axial (ax10) offset and somewhere around 1" in width. The bully axles are a bit narrower than bergs and can handle some offset.
Personally, I like the Wheel Works wheels...the new models can be had with several different widths...and the VP hubs should fit them nicely. If you are looking for something fairly cheap, then the LCC beadlocks should do the trick...although, I am not sure if they'll hold up to the weight of the bullys.
Old 04-27-2011, 09:07 AM   #6
I ran LCC wheels on my Bully for almost a year before they started cracking by the hex. They are a great wheel for the bully IMO. I had a pretty light bully though, around 5.5 lbs.
stubs179 is offline   Reply With Quote
Old 04-27-2011, 02:20 PM   #7
Thanks for the input guys, we'll probably run the lcc's for now.
build list so far:
BJ V4
bully axles
hitec 7980
W dot rovers
Holmes Crawl master 540's 32T
traxxas/losi shock setup
CI lower links
Esc's and remote still not ordered but should be soon. Once all the parts show up we'll post a build thread.
@Jeremy, wish I was making the comp this weekend but we'll for sure be present for may's galveston comp. Cant wait to see some pics
