12-13-2011, 02:29 AM | #1 |
Newbie Join Date: Oct 2011 Location: South Africa
| Bully wheel bolts coming loose
How do you secure your wheel bolts? Mine is coming loose all the time... I think I have the V6 Bully Comp 2.2 axles with the bolt, not the nut.
12-13-2011, 03:06 AM | #2 |
Pebble Pounder Join Date: Nov 2008 Location: Portugal, Porto de Mós, PNSAC Crawlers
In my case I put a little blue threadlocker, can not be much, just enough... |
12-13-2011, 08:22 AM | #3 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
I use the blue thread locker as well but I still have to tighten the bolt every pack or two.
12-13-2011, 09:19 AM | #4 | |
Better than the older axles with the nuts though. Even with nylon locking nuts, they would loosen up. I basically, swap batteries & check all the axle hardware (rear wheel nuts, front wheel screws). That way I won't be accused of having a "Screw loose", at least, not on my rig. | |
12-13-2011, 11:09 AM | #5 | |
Quarry Creeper Join Date: Apr 2010 Location: Centurion, GP, RSA
Some brands here is not blue but transparent for the removable thead lock. Do not use these as I found them to sieze sometimes. Rather get Locktite, 242, "Removable". I got the V6 rear axles. Now I cant go nuts but only have a "Screw loose"! | |
12-13-2011, 02:32 PM | #6 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
I found a combination that stays tight. Blue thread locker and wobble washers from true value. The washers look like regular flat washers that are bent.
12-13-2011, 03:40 PM | #7 |
12-13-2011, 05:18 PM | #8 |
Pebble Pounder Join Date: Jul 2011 Location: Oregon IL
Yup, I'm running Blue Locktite and lock washers. Haven't had a problem since I added the washers.
12-13-2011, 08:07 PM | #9 |
12-14-2011, 02:17 PM | #10 |
12-17-2011, 09:57 PM | #11 |
RCC Addict Join Date: Jul 2009 Location: Reno, Nv
| Re: Bully wheel bolts coming loose
Mine are really bad on VP hubs. The hubs don't fit tight on the v6 hex so forward to reverse loses them so fast. I check them every course.
