03-27-2013, 07:16 PM | #1 |
Newbie Join Date: Dec 2012 Location: Casper
| Bully Axle Help For Bully/Wraith
I am in the process of building a Bully/Wraith and I need some help with getting the proper links I need. I just ordered the axles and need to know the lower link mount width and the height from the lowers to the upper link mount. Just trying to be productive so I can build the links while axles are in transit so I can just bolt them in and go. I am going to try to use an extra set of Stage 1 aluminum wraith links if I can and just use bent uppers on the bottom, thanks guys!
03-28-2013, 03:14 AM | #2 |
RCC Addict Join Date: Jun 2006 Location: spotting for jeepsohigh
| Re: Bully Axle Help For Bully/Wraith
Are you looking to do what i have done in my build thread? If so there is a lot more you need to do before links, all of those pieces were machined to fit, none of it bolts together. Links also depend on chassis, setup, clearance issues, |
03-28-2013, 12:42 PM | #3 |
RCC Addict Join Date: Mar 2009 Location: Chilton
Like sniper said. Are you doing his mod? If so or even if your not there isn't really a way to make the links without the axles sitting right there especially when you are planning on doing something special like that.
03-29-2013, 07:49 AM | #4 |
I did see your build on it (NICE) and I actually found a guy in my town that had a busted rear one he let me borrow for mocking. I got the rear end done at least and was still able to use the Axial links but there were some minor clearance issues on the lower link mounts on the crossmember but the laser took care of that. I will get a build on here in the next few weeks. I also built a f/r dig using a 10C575 switch and a 120oz servo. OLD school but I am a cheap ***tard lol. Thanks for responding guys. I don't get on here very often, this covered wagon has a terrible wi-fi connection...
