Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > RC4WD Bully
Thread: Bully 2 front slw hub size?
Old 03-18-2014, 01:15 AM   #1
Default Bully 2 front slw hub size?
So I'm ordering my bully 2 front axle Wednesday, I'm building a interesting mix, bully 2 front/mt-dlux rear, dlux chassis/links and lots of hh parts. No added weight hopefully. The mt is already sitting on my desk. My lnc sporty build is 1 part from being done for now. so I'm starting to order stuff for this. I will post a build thread here in the b2 section when that axle is sitting on my desk as well. My budget for this build is <1700 including needing to get a 4pls system. The wheels will be dlux so the hub mounts to outer ring. Question is which slw hub to buy to get a good 11"+ track for the front? Thanks in advance
Liv3mind is offline   Reply With Quote
Old 03-18-2014, 07:28 AM   #2
Default Re: Bully 2 front slw hub size?
I have VP 725's on the front end of my B2. Thats using DE racing wheels which have pretty much the same offset as your typical 2 piece CF wheel. That puts my track width at just under 11" with Losi Boss claws and right at 11" using Ottsix Voodoo's
TURBOFEST is offline   Reply With Quote
Old 03-18-2014, 07:57 AM   #3
Running the same hub
chevotafun is offline   Reply With Quote
Old 03-18-2014, 09:52 AM   #4
Awesome you kids kick a-double-s. Pretty jazzed to get this going
Bully 2 front slw hub size? - Similar Threads
Need help choosing hub vp hub size Alamo71 Tires and Wheels 0 01-02-2014 07:05 PM
Hub size for bully craddock35 RC4WD Bully 4 07-27-2012 08:32 PM
Vanquish slw hub size XJkid93 Tires and Wheels 5 06-24-2012 05:02 PM
Vanquish SLW V3 on Bully Axles which hex hub size???? vodka child RC4WD Bully 17 07-16-2010 10:43 AM
