10-29-2016, 03:53 AM | #1 |
Newbie Join Date: Feb 2008 Location: somewhere
| swivel bully |
10-29-2016, 11:57 AM | #2 |
Pebble Pounder Join Date: Oct 2012 Location: Harleysville
| Re: swivel bully
I like where your going with this. How do you have the links attached to the swivel. Are you looking at dual or single esc? Keep posting and dont loose interest, I'm liking it!
10-29-2016, 10:05 PM | #3 | |
| Re: swivel bully Quote:
for now i think ill go for NOVAK rooster esc with 35T motor. by the way here's the latest in my project | |
10-30-2016, 06:49 PM | #4 |
RCC Addict Join Date: Jul 2008 Location: San Diego
| Re: swivel bully
Wow I have never seen a tube frame like this! Very interesting.
11-03-2016, 05:39 AM | #5 |
Newbie Join Date: Nov 2014 Location: usa
| Re: swivel bully
This is going to be a beast! Sent from my Lenovo TAB 2 A10-70F using Tapatalk |
11-04-2016, 04:39 PM | #6 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
| Re: swivel bully
Where are the pics?
11-04-2016, 05:14 PM | #7 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: swivel bully
Its photobucket. There down doing maintenance.
11-04-2016, 11:20 PM | #8 |
RCC Addict Join Date: May 2011 Location: at home
| Re: swivel bully
do you plan on adding some kind of limiter? 90 degrees of swivel should be enough, more than that could cause it to roll over easily. must say though, your approach to an articulated chassis is very attractive! ready to see more you can find a small thrust bearing to put in between the brass bushings. 1/4 inch thrust bearings and 1/4 inch pillow blocks is what I am using in mine. I have found thrust bearings as small as 1/8 inch. |
swivel bully - Similar Threads | ||||
Swivel Frame Power Wagon Build | OlYelr | 1.9 Scale Rigs | 165 | 05-21-2016 02:28 PM |
Wraith 360 Swivel Mount | jeepster73 | Videos! | 3 | 06-16-2013 04:00 PM |
6x6 Swivel Frame Semi | OlYelr | 1.9 Scale Rigs | 34 | 11-27-2012 07:28 AM |
Swivel Chassis Prototype | Jaydee | Tamiya Clod Buster | 11 | 09-18-2006 07:14 PM |
swivel socket shaft? | jeepguy | Tamiya TLT Crawlers | 2 | 02-23-2006 10:59 PM |
