01-16-2016, 06:19 AM | #1 |
Pebble Pounder Join Date: Jan 2012 Location: On the rocks
| Xr10 to Bully2
I have found the itch again to get back to crawling after a 3 year absence. I previously owned a pretty stock Xr10, Ax10 and a Wraith. I then built an Xr10 with all Vp bling and Chaotic Switch chassis. So here i am looking to build another crawler. I've ordered a chassis, B2 axles and some links. I will post my whole list of parts and some build pics as they come. As for now it feels good to be back and building again. |
01-16-2016, 11:50 AM | #2 |
| Re: Xr10 to Bully2
Well, I am on my way to a 2.2 comp rig. I am looking forward to the build and to try and make some comps this year. Here is my list for the build: Chassis-Sudu pro with carbon battery, electronics and servo mount Links-Dluxfab, Rc4wd steering Axles-Bully2 with 8* chubs and knuckles Shocks-Dlux big bores lathed with cap mod and mini t springs motors-HH puller 500 crawl 13t ESC-Torque master BR mini dual with castle BEC 7.4v Servo-Hitec 7950 Wheels-Vanquish SLW4, 475 hubs, Bully2 wheel weights, CI double deuce comp cut foams Tires-Ottsix Voodoo gold and silver I have the chassis, links, steering, shocks and axles ordered. I will post pics as the build comes along. Please give me feedback on what you think. |
01-16-2016, 12:49 PM | #3 |
RCC Addict Join Date: Jun 2007 Location: Finland
| Re: Xr10 to Bully2
That looks like a good list of parts you've got there. |
01-16-2016, 04:03 PM | #4 |
| Re: Xr10 to Bully2
Thanks, I am itching to get started with the build.
01-18-2016, 11:36 AM | #5 |
RCC Addict Join Date: Nov 2011 Location: Surrey,BC- Canada
| Re: Xr10 to Bully2
Yes I would agree that's a great list of parts to start with. Your going to have one killer rig |
01-18-2016, 12:08 PM | #6 |
| Re: Xr10 to Bully2
I hope so. Better rig than driver. Should have some parts in next week. |
01-18-2016, 12:11 PM | #7 |
| Re: Xr10 to Bully2
Should I go with 475 hubs, 600 or 475 front and 600 rear? Never had bully's before. |
01-18-2016, 01:39 PM | #8 |
Quarry Creeper Join Date: Apr 2011 Location: Estonia, Europe
| Re: Xr10 to Bully2
Fist of all - nice list of parts Last year I ran 600 all corners with CI 1" wheels. For this season I'm changing to 350 in the rear to get it a bit narrower. It's mainly because of the rocks we have, a lot of sharp turns into and out of the gates. |
01-18-2016, 02:24 PM | #9 |
| Re: Xr10 to Bully2
That's good advice, thank you. I might try 600 front with 475 rear and see how it works. I already have 350's from a previous crawler so I can always put them on instead.
01-24-2016, 10:28 AM | #10 |
| Re: Xr10 to Bully2
I am thinking of using dlux d-cut cf wheels. My question is if im using vp 600 and 475 hubs, what beadlockrims width on his sight should i use. I don't want glue on anything. I need advice on what to order. Thanks |
01-25-2016, 02:06 PM | #11 |
| Re: Xr10 to Bully2
Received my axles, knuckle weights and steering links in the mail. I should have my shocks and links from Dlux tomorrow. Stlii waiting for Sudu pro chassis, battery mount, electronics mount and servo mount. Also just ordered Dlux d-cut cf rims and vanquish hubs. I will post pics as i start to build. |
01-25-2016, 06:50 PM | #12 |
| Re: Xr10 to Bully2
600 front 475 rear. 10 3/4" front 10 1/4" rear wide |
01-26-2016, 06:52 PM | #13 |
| Re: Xr10 to Bully2
Thanks, that helps |
01-31-2016, 06:41 AM | #14 |
| Re: Xr10 to Bully2
Still waiting on my chassis and plates from Dravtech. I have to order some tires and i will start putting together a rolling chassis. Im thinking of going with bully comp ties from Rc4wd. How do they compare to Voodoos? I will post pics once i get everything i ordered. I would like to send a shout out to Eric from Dlux, his parts and service are second to none. Thanks Eric |
02-02-2016, 06:19 PM | #15 |
RCC Addict Join Date: May 2012 Location: Montreal, Qc
| Re: Xr10 to Bully2
They are very similar, except the RC4WD Bully are narrower, a very good thing, and the OD is a bit smaller... They allow an enormous amont of steering without hitting shocks or lower links... The compound is very sticky and soft... A lot of grip... Only thing is the foams are way too soft, useless... CI double deuce is the only way... Last edited by noname0383; 02-02-2016 at 06:21 PM. |
02-03-2016, 01:28 PM | #16 |
| Re: Xr10 to Bully2
Can't post pics
02-07-2016, 03:46 PM | #17 |
| Re: Xr10 to Bully2 Bully 2 with knuckle weights. Sudu Pro chassis Dlux lathed Big Bores Dlux d-cuts |
02-08-2016, 05:41 PM | #18 |
| Re: Xr10 to Bully2
Thanks for the likes guys. I am putting a roller together for now to get things somewhat dialed in. Just ordered a couple sets of tires, some wheel spacers from Dlux and some no preload cups for my shocks. I should have went with 725 hubs up front cause my back screws for the Dlux wheels are hitting my steering arm barely though. Didnt want to buy new hubs so i went with the hub spacers. More pics to come soon. |
02-12-2016, 06:05 PM | #19 |
| Re: Xr10 to Bully2
Just got back from out of town for work. Saw a package from rc4wd and still waiting for my dlux package. I will post picks of roller when I have time to work on it. Thanks to all for advice and the great parts. |
02-15-2016, 08:21 PM | #20 |
| Re: Xr10 to Bully2
Here are some pics of the roller. 3mm plastic shock standoffs New bully comp tires Still waiting on wheel spacers and shock preload cups. Hope you like. |
Xr10 to Bully2 - Similar Threads | ||||
g-jero,s Bully2 | g-jero | RC4WD Bully | 21 | 05-11-2015 08:45 PM |
Few things about the Bully2 | Colgout | RC4WD Bully | 6 | 01-30-2014 11:52 PM |
