07-30-2016, 07:06 PM | #1 |
Newbie Join Date: Dec 2013 Location: washington
| My First MOA......Bully 2
Received my new Bully 2 almost 2 weeks ago. I changed the shock location and put the lighter springs in. 30wt in the front and 60wt rear. Basically took cboggs suggestions. I didn't decase the esc or dig unit so they wouldn't fit down below. I did relocate the receiver and bec down below though. Cleaned up all of the motor leads. Also added a stronger servo. I ran it last weekend and am pretty happy with it. Drives a little different than my deadbolt/ UGC fastback. The dig feature works well. I would suggest going through the rig before running it. I did not and had a lot of stuff loosen up. Here's a few pictures. Sent from my SCH-I545 using Tapatalk |
07-30-2016, 07:20 PM | #2 |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: My First MOA......Bully 2
Looks good, always go through a new rig before you drive it.. If I were you I'd check the gear boxes for grease.
07-30-2016, 07:26 PM | #3 |
Thanks, I will double check them. Sent from my SCH-I545 using Tapatalk |
07-30-2016, 11:16 PM | #4 |
5th D Owner/Driver Join Date: Dec 2005 Location: Snoqualmie, Wa.
Clock those C's/knuckles back also. |
07-31-2016, 02:49 AM | #5 |
Rock Crawler Join Date: Jul 2006 Location: The Netherlands
Clock the chub, and also more the steering link to the upper side of the knuckle.. And the drag link on top of that. Then the drag link runs flat and not in a angle like it does now Verstuurd vanaf mijn Nexus 6P met Tapatalk |
07-31-2016, 05:38 AM | #6 |
I wanna be Dave Join Date: Nov 2005 Location: Here
| Re: My First MOA......Bully 2 |
07-31-2016, 10:27 AM | #7 |
Thanks guys! I will rotate the chubs and move the steering links. Also going to order the knuckle weights and longer link ends for the rear upper links. Sent from my SCH-I545 using Tapatalk |
07-31-2016, 07:31 PM | #8 |
Rock Stacker Join Date: Jun 2016 Location: Beaverton
Nice. I put a few packs through mine this weekend. Definitely needs some tuning. Biggest gain out of the box would be venting and trimming the tires. Needs a good amount of weight up front too. Otherwise a great rig (my first moa)
My First MOA......Bully 2 - Similar Threads | ||||
Mk42 Moa or bully Moa... Which is a better choice? | Oregon crawler | Newbie General | 3 | 08-04-2011 01:26 PM |
my 2.2 moa bully | Superclass | RC4WD Bully | 4 | 07-04-2010 01:37 PM |
First MOA *Bully | smm_cbf | RC4WD Bully | 2 | 01-01-2010 09:25 PM |
