05-18-2017, 03:12 AM | #1 |
RCC Addict Join Date: Jun 2007 Location: Finland
| Lilla My Lilla My Technical data: Axles: RC4WD Bully 2 Chassis: DravTech SuDu MOD 3D Links: Dlux Fab Motors: Holmes Hobbies Puller 500 Team 13t XX (coming) ESC's: Holmes Hobbies Dual BR-Mini Servo: Holmes Hobbies SHV500 Batteries: Turnigy Nano-Tech 850mAh 45-90C 3S LiPo Tires: E.Y. Designs Narrowed Ottsix Voodoos (Narrow gold in front ja ultra narrow silver in rear) Wheels: Dlux Solid Face CF (0.87" in front and 0.72" in rear) Foams: Crawler Innovations Double Deuce (6.0" Soft in front with medium tuning foam ja 5.5" Medium in rear) Shocks: DravTech Comp Shocks Springs: DravTech Ultra soft Radios: Sanwa MT-4 Skins: Krawler Konceptz Else: - DravTech servo tray - DravTech battery tray - DravTech electric tray - Dlux fab brass knukcles - Dlux fab titanium link sliders Last edited by Zarizi Tech; 05-18-2017 at 04:05 AM. |
05-18-2017, 03:13 AM | #2 |
| Re: Lilla My Chassis, links and suspension Chassis: DravTech SuDu MOD 3D (145$) Skins: DravTech SuDu MOD 3D (10$) or Krawler Konceptz (90$) Links: Dlux Fab SuDu MOD 3D (95$) Titanium link sliders: 8x Dlux Fab Titanium Link Sliders (32$) Rod Ends: 8x Traxxas to upper links (6$) and 4x Revo (3$) also 4x Jato (3$) to lower links Shocks: 2x DravTech Comp Shocks (80$) (Choose colour and pick medium springs) Springs: DravTech Springs (5$) (Pick soft springs) Rebuild kit: 2x Traxxas Big Bore Rebuild Kit (7,5$) Rod ends: 2x Traxxas Short Rod Ends (7,5$) Fluids: Team Losi Racing 15wt Shock Oil for shocks (4$) Associated Green Slime to O-Rings (3$) Building costs so far: 401$ + taxes and shipping costs Last edited by Zarizi Tech; 05-19-2017 at 05:38 AM. |
05-18-2017, 03:13 AM | #3 |
| Re: Lilla My Axles and tires Axles: RC4WD Bully 2 front axle (180$) and RC4WD Bully 2 rear axle (170$) Knuckles: Dlux Fab Steering Knuckles (87$) (Choose: Brass - Axial Wraith/XR - Bully 2 - Nothing - Both single ended - Brass - Brass) Front shafts: Dlux fab B2 - XR Universals (Ask Erik) (110$) [[MODIFICATION: Inner diameter of the axle tubes need to be increased with 7mm drill. Axle housing from the shorter side needs to be drilled as well to make the shaft fit all the way to the locker.]] Pinions: 2x Robinson Racing 14t (Choose 14t) (12$) Battery mount: DravTech Bully 2 battery mount (13$) Servo mount: DravTech Bully 2 servo mount (15$) Electronics tray: DravTech Bully 2 electronics tray (18$) Fluids: Vanquish Products Super Star Lube in the axles (8$) Wheels: Dlux 2.2 Wheels (Rear wheels, choose: Carbon fiber Solid face - Carbon fiber - 1.030 (.750) - Silver Stainless - Aluminium - Nothing) (Front wheels, choose: Carbon fiber Solid face - Carbon fiber - 1.155 (.875) - Silver Stainless - Aluminium - Nothing) (84$) Tires: Front: Ottsix Voodoo Gold (Choose: Gold) / Narrowing service (72,5$) Rear: Ottsix Voodoo Silver (Choose: Silver) / Ultra narrowing service (70$) Foams: Front: Crawler Innovations Double Deuce 6,0" Narrow Comp Cut inner - Soft Outer (18$) Rear: Crawler Innovations Double Deuce 5,5" Narrow Comp Cut inner - Medium outer (17$) Wheel hubs: Front: Vanquish Products SLW 725 (19$) Rear: Vanquish Products SLW 225 (19$) Hub screws: 2x Vanquish Products 4-40 Screws (11$) Building costs so far: 1325$ + taxes and shipping Last edited by Zarizi Tech; 05-19-2017 at 05:28 AM. |
05-18-2017, 03:13 AM | #4 |
| Re: Lilla My Electronics Radios: Sanwa MT-4 (250$) ESC's: Holmes Hobbies Torquemaster BR-Mini Dual (175$) (Choose: Install XT60 Plug - Nothing) Motors: 2x Holmes Hobbies Puller 500 Team (Choose: TEAM Puller 500 Crawl 13t XX - Nothing - (your colour choise) - (your colour choise) - Forward (counterclockwise) - Yes) (250$) Servo: Holmes Hobbies SVH 500 (120$) (Choose: No) Batteries: 3x Turnigy Nano-Tech 850mAh 3S 45~90C Lipo Pack (33$) Charger: Turnigy P606 LiPoly/LiFe AC/DC Charger (EU Plug) (US Plug) (UK Plug) (40$) Building costs so far: 2193$ + taxes and shipping Last edited by Zarizi Tech; 05-19-2017 at 11:41 PM. |
05-18-2017, 03:14 AM | #5 |
| Re: Lilla My Finishing touches and sum up Screws, bolts and spacers: RC4WD Crawler Screw Bag (40$) Servo horn: Robitronic 25T Servo Horn (16$) Battery connectors: Male XT60 Connectors (2,5$) Velco strap: Walkera Velco Strap 250mm (1$) Battery holding peel: 3M Dual Lock (5$) Heat shrink: Turnigy Heat Shrink 5mm (1,5$) Zip ties: Cable Ties 150mm X 3mm (3$) Final price: 2262$ + taxes and shipping Recommended setup Shock building: DravTech Comp Shocks building guide Knuckle building: Dlux Fab Knuckle building guide Font upper link mount to the middle hole on the axle and upper links to the uppermost hole on the mount. Caster angel of the hubs should be close to zero degrees. Better to have slightly positive angle. Not much though. Rear upper link mount to the middle hole on the axle and upper links to the middle hole on the link mount. On front axle shocks should be on the highest hole and lower links on second lowest hole of the shock/link mount. Both should be attached inner side of axle. On front axle the the shock/link mount should be attached to the outer holes on top of the axle. On rear axle the shocks should be attached on the highest and lower links on second lowest holes of shock/link mount. Both should be attached inner side of axle. On rear axle the shock/link mount should be attached on the outer holes on top of the axle. Rear shocks should be attached to the first holes from rear with 3mm washer coming placed shock and chassis. Front shocks should be attached to the third holes from the front with 6mm spacer placed between shock and chassis. Last edited by Zarizi Tech; 05-21-2017 at 03:58 PM. |
05-18-2017, 03:17 AM | #6 |
| Re: Lilla My
My purpose here is to make a proper build topic, where I will tell where to buy all the components needed on this build with their links and costs. With this topic you can select all the stuff to shopping carts and order everything if you want. It's well proven to be world class setup finishing on podium in 2016 Worlds. I will start updating, please subscribe. |
05-18-2017, 07:59 PM | #7 |
Rock Stacker Join Date: Aug 2013 Location: NZ
| Re: Lilla My
Ermmm so the total cost of $401 + tax & shipping, that must not include the axles you have pictured? Perhaps a bit misleading as you say "building costs so far $401 + tax + shipping", and show a picture with the chassis, axles, links and everything else together. So its $401 + tax + shipping + how much for the axles? Or how is it so cheap? free axles? Cool build though Last edited by nzcrawl; 05-18-2017 at 08:02 PM. |
05-18-2017, 08:37 PM | #8 |
| Re: Lilla My
Follow along to the next installment , that's where he builds axles and tires, I suspect host will be part Hang up and Drive |
05-19-2017, 05:29 AM | #9 | |
| Re: Lilla My Quote:
Exactly. | |
05-19-2017, 11:42 PM | #10 |
| Re: Lilla My
Next phase: electronics added to fourth message. |
05-20-2017, 04:58 AM | #11 |
Pebble Pounder Join Date: Nov 2013 Location: Southeast MI
| Re: Lilla My
Really great to have a "cheat sheet" here that is pretty close to the plan I was putting together. Thanks :-)
05-20-2017, 06:01 AM | #12 |
| Re: Lilla My
Rolls Royce of crawlers. First class ! Hang up and Drive |
05-20-2017, 06:14 AM | #13 |
Quarry Creeper Join Date: Feb 2012 Location: Alphen Aan Den Rijn
| Re: Lilla My
No bec option on the dual esc from holmes ????
05-20-2017, 06:58 AM | #14 |
| Re: Lilla My
No need for a bec, the servo is powered direct off the batt Hang up and Drive |
05-20-2017, 12:48 PM | #15 |
Quarry Creeper Join Date: Apr 2012 Location: So. Cal.
| Re: Lilla My |
05-20-2017, 02:28 PM | #16 |
| Re: Lilla My
Nada..... plug and play Hang up and Drive |
05-20-2017, 02:29 PM | #17 |
Quarry Creeper Join Date: Dec 2016 Location: westlerly
| Re: Lilla My
I thought Erik wasn't making the xr unis for bully 2s anymore. I've asked not very long ago.
05-21-2017, 04:02 PM | #18 | |
| Re: Lilla My
The last update is now added on the fifth message of this thread. I do hope this will help people finding parts and tuning their SuDu Bullies. Quote:
Yeah, it is a pretty decent setup, thanks! No need, since I can run power straight from battery to servo. That might be true. Well, every job has it cost. I bet he can come up with alternative if needed. | |
05-21-2017, 11:27 PM | #19 |
Pebble Pounder Join Date: Jul 2011 Location: Germany
| Re: Lilla My
Excellent write-up! Thanks for sharing Samu |
05-26-2017, 01:03 PM | #20 |
RCC Addict Join Date: Nov 2011 Location: Surrey,BC- Canada
| Re: Lilla My
Sweet write up bud, But dam Samu did you really have to tell us how much we really spent on our toy cars Last edited by chevotafun; 05-26-2017 at 01:14 PM. |
