01-27-2012, 04:11 PM | #1 |
Rock Stacker Join Date: Apr 2009 Location: brisbane, Australia
| RC4WD Trailfinder 2 help thread.
Seeing as the team drivers have these in their hands now. I'd like to ask them all and those that get them if they can see any design faults or possible weak links with these kits? Are there any tips and special technics that my be used when assembling this great new kit? I could have posted in every thread but decided against it, maybe this could be a sticky as to not get an influx of "help" threads. Last edited by nitro_star; 02-01-2012 at 12:44 PM. Reason: Bad choice of words. |
01-27-2012, 04:38 PM | #2 |
RCC Addict Join Date: Dec 2007 Location: London
| Re: Design flaws or weak links?
Well I was one of the First to get there's up and running. One thing I have changed is the Sliders In my Opinon I think that they stick out a little too far. This is what I did. Before After Its a Free Mod too which is the best one in my eye's Here's underneath As you can see I just cut the Sliders down by around 10mm where they mount to the chassis. Using a Sharp Stanley Knife I had to re drill the inside hole with a 2.5mm drill bit To make the Hole a little longer. No need to use a Tap, (although you could if you wanted) the M3 Bolt wound in making a new thread. Sorted. And its called the 'Dready Slider Mount Mod' Neil |
01-27-2012, 04:44 PM | #3 |
Thanks for that Neil. I figured there would be some lil things that people would notice once they had them. It will make it easier to find lil tips and tricks in one thread.
01-27-2012, 04:46 PM | #4 |
| Re: Design flaws or weak links? |
01-27-2012, 04:51 PM | #5 |
now to sweet talk the wifey |
09-02-2014, 12:53 AM | #6 |
Pebble Pounder Join Date: Jan 2011 Location: Peace and Quiet
| HELLLPPP Pllleeeeaaassseeeee :(
Im looking for the over all frame width dimensions, the end to end frame only dimensions, and the front of frame to center front wheel dimension and the rear frame to center wheel detentions... MM are my preferred measurements.. A to B A to C outside to outside A to D B to E Thank you guys, it for a new custom scaler project... |
RC4WD Trailfinder 2 help thread. - Similar Threads | ||||
My new chassis design - bodyless tvp design. | monkeyracer | Axial AX-10 Scorpion | 100 | 06-17-2009 07:53 AM |
Some Search Engine Flaws Here? Or Is It Just Me? | TheHeadHunter | Chit Chat | 4 | 11-20-2008 07:03 PM |
ARTR flaws | Canz Crawler | Newbie General | 6 | 07-29-2008 12:44 AM |
WK Weak Links - What Breaks? | todd1803 | HPI Wheely King | 5 | 05-29-2007 10:35 PM |
