04-15-2012, 02:49 PM | #1 |
Rock Crawler Join Date: Aug 2011 Location: Baton Rouge
| TF2 and other axles
Has any one used different axles for there TF2 and if so , please post up pics if you can!! Came across a TF2 except axles and trying to figure out which axles should I go with ...Axial axles or some Trex 60? Your help is greatly appreciated. |
04-15-2012, 03:45 PM | #2 |
RCC Addict Join Date: Dec 2007 Location: London
| Re: TF2 and other axles |
04-15-2012, 03:50 PM | #3 |
Old guy Join Date: Jan 2007 Location: Northwest Arkie-saw and we got ROCKS!
I got some 44s I'm going to put on mine, but it might be awhile before I do.
04-15-2012, 05:24 PM | #4 |
REST IN ALOHA CHIP Join Date: Nov 2005 Location: *
i also plan on putting the K44s on mine. but, like Ricky...im gonna use the yota axles for a while. you'll see them on the final assembly of my rebuild. Ive confirmed that the leaf springs will indeed line up for proper fitment, and the 4 link conversion is pretty much straight forward for both axles.
04-15-2012, 08:44 PM | #5 |
I have some t Rex 60 I was thinking about throwing on there. That's why I wanted to see what's others are using.
04-15-2012, 09:03 PM | #6 |
Rock Crawler Join Date: Jan 2007 Location: UK
K44 are a direct fit but you will need the new knuckles: K44 Knuckles For Trail Finder 2 Front 4 link kit is not as straight forward as the rear due to the tranny being low. |
04-15-2012, 10:46 PM | #7 |
| Re: TF2 and other axles i believe the t rex 60 uses a very similar bolt pattern for the leaf springs, you may find that you'll like the ground clearance from the yota axles better...both are very strong though.
04-15-2012, 11:15 PM | #8 |
Quarry Creeper Join Date: Jun 2011 Location: butler pa
I have the ballistic rc4wd in mine direct bolt up, slight mod to the drag link
04-16-2012, 01:18 AM | #9 |
04-16-2012, 06:17 AM | #10 |
04-16-2012, 08:47 PM | #11 |
Balistic axle is basically a TRex60 so these will fit: XVD Axle for T-Rex 60 |
04-16-2012, 09:02 PM | #12 | |
| Re: TF2 and other axles Quote:
04-17-2012, 10:32 AM | #13 |
Can I just use the leaf kit from rc4wd for the t Rex on the leafs supplied in the tf2 kit?
04-17-2012, 07:49 PM | #14 |
Yes all our leafs have the same mounting holes.
TF2 and other axles - Similar Threads | ||||
Slowbro's TF2 | Slowbro | RC4WD Trail Finder 2 | 54 | 02-13-2015 02:32 PM |
Another country TF2 | adbradwell | RC4WD Trail Finder 2 | 22 | 12-27-2012 05:37 AM |
Tf2 | Snowwheeler | RC4WD Trail Finder 2 | 14 | 08-20-2012 09:39 PM |
