05-03-2012, 11:17 AM | #1 |
Rock Crawler Join Date: Jun 2011 Location: Las Vegas/671
| Connecting or disconnecting battery with body on.
Anyone have a trick to connecting the battery to the esc while the body is on? I can't get my hands in there to do anything. I don't want to have to remove the body everytime I shut it off. If anyone has a easy way, I'm all ears...Thanks |
05-03-2012, 11:55 AM | #2 |
Rock Crawler Join Date: Jan 2010 Location: Pacifica, CA.
| Re: Connecting or disconnecting battery with body on. Some guys are cutting a hole in the bed and putting the battery in there, others are making a tool box to hide the battery in the bed, and some are using velcro/magnets to attach the body.
05-03-2012, 01:04 PM | #3 |
Rock Crawler Join Date: Oct 2009 Location: Danish badlands
I have good experinces with using rare earth magnets to keep my jeep body on my honcho,but it should be mentioned that i allso use the floore pan from proline witch allso aid in keepind the body in place. Cut down the front 2 body posts put on a little rubber hose in witch i then put 2 magnets ( aprox 4 x 15 mm round ) and then glued in 2 metal strips under the hood over the magnets. in the rear i glued 2 simmilar magnets in the bed pan where the body allso is, and then like the front i glued in 2 metal strips on the body oposing the 2 magnets. still works like a charm but will launch body shell and possibel the battery if rolled severly Light camera "action" - YouTube Green body in there allso carry a 2250 1S battery for light attached to back of cabin. ditching it at 1:50 |
05-03-2012, 07:20 PM | #4 |
RCC Addict Join Date: Feb 2012 Location: Ca.
I'm also looking for a way to mount my body so as not to have to remove it each time to change the battery. I may try your method, thanks. Also, I just watched your video, those are very bright lights, nice job. |
05-04-2012, 05:05 AM | #5 |
I wanna be Dave Join Date: Apr 2009 Location: Unnecessary Surgery Land
Make the hood open |
05-04-2012, 11:49 AM | #6 |
RCC Addict Join Date: Dec 2007 Location: London
Battery in an opening Toolbox for me |
05-05-2012, 11:56 PM | #7 |
I decided to put extensions on my battery and esc, I removed the rx box to the rear and it makes it easier to pull out the wires and tuck it back in. Thanks to all for sharing. |
Connecting or disconnecting battery with body on. - Similar Threads | ||||
Connecting battery and motor to esc | hansmoolman | Newbie General | 24 | 09-15-2011 04:16 AM |
Disconnecting Sway Bar | RickM | General Scale Talk | 5 | 12-07-2010 11:34 AM |
connecting rod question | crawlin'scorpion | General Crawlers | 3 | 04-21-2006 10:35 AM |
Concept: Disconnecting Pede Tranny | CronusTRD | Tamiya TLT Crawlers | 7 | 03-06-2006 04:33 PM |
Disconnecting Tamiya connectors without unsoldering? | Trike Kid | Electronics | 4 | 10-19-2005 09:14 PM |
