06-19-2012, 01:47 AM | #1 |
Quarry Creeper Join Date: Jan 2010 Location: vancouver, canada
| chino soft red leafs?
would you recommend chino-ing super soft red leafs? i guess it's all preference and this might be a redundant question, if so i apologize, but i looked through 5 pages on the forum to find no answer. opinions? thanks! |
06-19-2012, 02:33 AM | #2 |
Pebble Pounder Join Date: Feb 2011 Location: Northwich, England
| Re: chino soft red leafs?
I tried it with one pair of mine and found that the spring kept popping off the fixed (non-shackle) end. I may well have trimmed the end of the spring a little to much, in the end I cut the ends off the springs and used them as helpers. Pete |
06-19-2012, 06:50 AM | #3 |
RCC Addict Join Date: Feb 2012 Location: Ca.
I'm afraid I don't know what it means to CHINO the springs. Could someone explain this to me please? Thanks Joe |
06-19-2012, 09:52 AM | #4 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
The Chino mod is when you grind or bevel the eyelets at the ends of the leafsprings at an angle to allow them to rotate slightly on the mounts. The idea is to get them to move in an arc with the axle during articulation. The Chino'd eyelets look like this: / \ Instead of this: | | (when viewed from the end) Last edited by TrailDawg362; 06-19-2012 at 10:04 AM. |
06-19-2012, 12:18 PM | #5 |
Thanks TrailDawg362.
06-19-2012, 02:50 PM | #6 |
Pebble Pounder Join Date: Oct 2008 Location: mid state
ummmm? wouldntmodding the leaf springin that manner not do anything at all since the boltthat holdsthemand the diameterofthe leafspringeyelet are of the same size no matter if you ground them? now i could see doing the mod whereyou actualy grind the bolt that goes through the leafspring eyelet then i could see that addign morearticulation to the leaf springsince the leafspringeyelet willhave room to wobble in either direction? but i could be wrong? bob |
06-19-2012, 11:16 PM | #7 |
Grinding a double taper on the shackle bolts would be the next step for added flex beyond Chino'ing the leafsprings. I thought I read that mod somewhere in this section. I haven't done either of these things to my TF2 (yet), so at this point I'm just relaying the info I've picked up over the years . Hopefully it is of some use.
06-21-2012, 12:05 AM | #8 |
thanks gents! chino to start it is!
chino soft red leafs? - Similar Threads | ||||
RC4WD soft leafs and softer coli over springs? | emaxxjeremy | General Scale Talk | 5 | 09-07-2008 09:52 PM |
chino mod leafs | LorenzoZ | Newbie General | 4 | 12-08-2007 09:31 PM |
