10-07-2013, 05:01 PM | #1 |
Rock Crawler Join Date: Jul 2012 Location: Grand rapids
| Destroying front diff gears
So I've had a tf2 for a little over a month and went threw two sets of diff gears, is anyone else having this issue, they are stock and I'm not running xvds, motor is a 45t HH and sv3 on 2s, any idea why this is happening.
10-07-2013, 05:23 PM | #2 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
| Re: Destroying front diff gears
Are the gears shimed right , If not the ring and pinion will definitely get torn up quick.
10-07-2013, 05:28 PM | #3 |
I got the truck from another member, when the first set blew I just put it back together the way I took it apart
10-07-2013, 06:55 PM | #4 |
When you get your new gear make sure all the old grease and metal shaving are cleaned out , Then after you put the new gears in check the backlash. You dont want a lot of slop in between the gears , Once your get them setup grease them up are check them again. |
10-07-2013, 07:00 PM | #5 |
I got it all cleaned up today, and installed them to check it out, how would I go about shiming it if I got to, do I do it to the main gear in the axle or the 3rd member gear, I'm still new to the tf2, I'm used to axial, replace and go
10-07-2013, 07:07 PM | #6 |
If you don't need to much you can just shim the pinion inward . If thats not enough that you'll have to shim the ring gear.
10-07-2013, 07:55 PM | #7 |
Rock Crawler Join Date: Jul 2012 Location: Albuquerque, New Mexico
Could you post a write up in how to do it and what's needed. I would find that useful.
10-07-2013, 08:16 PM | #8 |
Rock Stacker Join Date: Nov 2011 Location: Huntsville, Al
Simple. Shimming the pinion: Remove the 3rd, pop the e-clip off the pinion, push the pinion out, add a shim(rc4wd sells shim kits on their site), reinstall the pinion, put the third back in(to check it I usually put 4 screws in), and rotate the pinion if it sounds rough and feels gritty remove the shim you added, if it still feels loose add another shim. Repeat until your satisfied. I haven't had to shim a ring yet but I'd imagine it's similar to an MRC I'd guess it's: remove the third, take the knuckles off, pop out the axles, add a shim on the flat side of the ring, put the third in and spin. Listen for the same as above. Hope this helps, I kind of pulled how to shim the ring out of my butt but I'd imagine it's pretty close. IIRC I had to add 1 shim to the pinion on mine. 2 and it got rough. Ben Last edited by 88RRC; 10-07-2013 at 08:22 PM. |
10-19-2013, 06:51 PM | #9 |
Well after installing a new set if gears with some fine checking before putting the case back on and the first 10 mins out today, shredded the gears, it's getting old, is it that I don't have the xvds in?
10-19-2013, 06:53 PM | #10 |
Shimming them properly and greasing them up should take care of it. I've run mine pretty hard this summer and both my axles are nice and tight.
10-19-2013, 08:28 PM | #11 |
What shims do you use? I looked on their site and don't see any for the yota axles
10-20-2013, 01:30 PM | #12 |
All I had to do (front AND rear) is swap around the shims that were already installed on the pinion shafts. I can't believe RC4wd is shipping these trucks so loose. Mine is still not as tight as I'd like AFTER swapping around the shims the way RC4wd assembled them. In my case they had a fat shim on the outside and a thin one on the inside. Pushing/pulling the pinion away from the ring gear. After I swapped them I had an OK gear mesh. I don't have any shims small enough to adjust it any closer without getting too tight but it's better than leaving it alone and hoping for the best.
10-21-2013, 11:23 AM | #13 | |
| Re: Destroying front diff gears Quote:
10-21-2013, 01:09 PM | #14 | |
RCC Addict Join Date: Aug 2011 Location: round pond (aka clarksville TN)
10-21-2013, 01:12 PM | #15 |
Gotcha , I'll try it out, thanks for the help, now I gotta buy ANOTHER gear set, kinda sucks
11-04-2013, 03:18 PM | #16 |
Well rc4wd was cool enough to send me a set of gears and shims, did some test fitting while shiming the pinion gear. Nice and smooth but yet close fit, and 2 mins out they shred! I thought about shiming the ring gear but it's already a snug fit in the axle, I'm at a loss on this one
11-04-2013, 04:01 PM | #17 | |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
What power are you running? Your ring and pinion should be like your inion and spur gear mesh. It should be tight but should still be free moving. Take a picture of how you set up your next gear set and let us check it out for you. It does sound like your ring gear is 70% of your problem. | |
11-04-2013, 04:10 PM | #18 |
I'm running a HH 45t and a sv3 on 2s, and my tf2 has the gelande single speed tranny in it, I've got another set coming. It's starting to aggravate me. I love the truck but damn, I can have the front apart in about 6 mins lol
11-04-2013, 04:20 PM | #19 | |
I'm still perplexed at how you're destroying gears like that. It isn't like you are running high power or high voltage. Are you just destroying them on mild obstacles or are you "rock bouncing" it? Also, how tight is your slipper clutch? It's crazy because I'm running Yota axles with a 35T on 3S with a rig that weighs close to, if not, 9 lbs. The most and only thing I have broken is a drive cup on the short side axle shaft. | |
11-04-2013, 04:24 PM | #20 |
Lol yeah should be gear shredder, and no I'm not rock bouncing it, I'm running on small scale course nothing crazy. And the slipper isn't super tight but isn't super loose it kicks in if it's in a bind , and it only weighs about 6lbs I don't have the camper mounted yet for it.
Destroying front diff gears - Similar Threads | ||||
Diff gears | OKJeepin | Losi Mini-Rock Crawler | 2 | 04-23-2012 06:01 PM |
independent front suspension and front diff build | canadian scx10 | Axial SCX-10 | 1 | 02-13-2011 07:52 PM |
diff gears? | venom-crawler | General Crawlers | 2 | 07-10-2008 04:47 PM |
Destroying 2.2 wheels | RD400 | Tamiya TLT Crawlers | 14 | 08-26-2005 11:53 AM |
