02-20-2014, 05:29 AM | #1 |
Newbie Join Date: Feb 2014 Location: Milwaukee
| Midwestaaron builds a trail finder 2
So it's been a few years since I've had an rc, so I did some research a found one I liked, read up on the forums to see the strong and weak points, and got to ordering a few things. Just got my trail finder 2 last night, got the frame assembled, also decided to go with the tough armor metal bumpers and sliders, xvd axles, and will be ordering the punisher drive shafts. Plans for the truck are to keep it simple, won't have time to do a lot with a growing family. Any tips a tricks or preventative measures welcome, feedback and comments welcome.
02-20-2014, 09:27 AM | #2 |
| Re: Midwestaaron builds a trail finder 2
I would order the helical gears. Make sure the axle gears are shimmed properly. Also check bearing seats on the axle for gears, make sure clean and free of powder coating. Destroying front diff gears |
02-20-2014, 11:44 AM | #3 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
That's very good advice, check the axles and diffs closely. Shim as needed and lube everything. I heard several comments about the trans being under-lubed also. I popped open the 2 speed case and gave mine a healthy dose of Mobil 1 synthetic and also hit the T-case right away.
02-21-2014, 12:05 PM | #4 |
Great, thank you! This will probably be a pretty slow build seeing as I'm expecting a beautiful baby girl very soon. Also I plan on getting the interior as well. Going to go the extra step and try to make this waterproof too.
03-04-2014, 02:54 PM | #5 |
| Re: Midwestaaron builds a trail finder 2 Last edited by Midwestaaron; 03-04-2014 at 03:02 PM. |
03-04-2014, 04:11 PM | #6 | |
RCC Addict Join Date: Feb 2012 Location: Ca.
| Re: Midwestaaron builds a trail finder 2 Quote:
03-04-2014, 04:41 PM | #7 |
I was wondering the same but I found in my toolbox some a/c compressor shims that might work. And i wasn't going to worry too much until I get the helical gear sets.
03-05-2014, 01:15 AM | #8 | |
Shimming the diffs just means using thin washers behind the pinion gear to bring it in tighter to the ring gear for less slop in the mesh. The side to side play in the diff assembly can also be shimmed behind each bearing to keep the gears from moving away from each other. When done properly, the ring and pinion should rotate and engage smoothly with minimal play between the gears. Hope that helps , Last edited by TrailDawg362; 03-05-2014 at 01:21 AM. | |
03-05-2014, 01:30 AM | #9 |
Newbie Join Date: Feb 2014 Location: Oakland
i never shimmed mine anything more than the instruction manual instructed, but i packed the hell out of my axles with marine grease and my diffs seem like they are really happy and have lots of fight !!! i hope they don't blow up anyways haha <3
03-05-2014, 05:14 AM | #10 |
Yeah, I need to get some marine grease too. And I figured shining the scale one would be the same as doing a full size one.
03-05-2014, 06:23 AM | #11 | |
03-07-2014, 07:40 AM | #12 |
Thinking about getting the aluminum bumper mounts as well. Opinions?
03-08-2014, 05:49 PM | #13 |
| Re: Midwestaaron builds a trail finder 2 |
03-08-2014, 09:16 PM | #14 | |
Quarry Creeper Join Date: Dec 2009 Location: West Alabama
meh... depends on what bumpers you plan on running and what function they will serve (mosly if you plan to mount winch to bumper) i have chopped the stock plastic bumpers down to nothing more than a straight bar just for looks, so plastic mounts is all i need. | |
03-09-2014, 07:45 AM | #15 |
I have the tough armor bumpers now, and plan on putting a winch on in the future.
Midwestaaron builds a trail finder 2 - Similar Threads | ||||
evidence trail buster 1 9 on the scale of RC4WD Trail Finder 2 | gionata78 | Scale Videos! | 2 | 11-10-2013 12:19 AM |
Part 2: 16 Trucks beach Trail: Land Rover Defender Dingo Honcho Trail Finder 2 Ford h | boolean21 | Scale Videos! | 0 | 09-09-2013 07:42 AM |
13 Trucks mudding at Wallace Trail - Trail finder 2 tundra honcho dingo hummer Unimog | boolean21 | Scale Videos! | 0 | 10-17-2012 05:11 PM |
13 Trucks mudding at Wallace Trail - Trail finder 2 tundra honcho dingo hummer Unimog | boolean21 | Scale Videos! | 0 | 10-17-2012 05:09 PM |
25 Trucks beach Trail: 15 Land Rover Defender scx10 Trail Finder 2 Wraith hilux Tundr | boolean21 | Scale Videos! | 6 | 08-22-2012 04:07 PM |
