10-21-2014, 06:09 PM | #21 | |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
| Re: Brand New RC4WD Trail Finder 2 w/BROKEN TRANSMISSION GEAR Quote:
I had a couple of packages of misc sized shims that I picked up at an LHS and used an assortment on either side of the ring bearings to reduce the left-right play. I might have even thrown a washer or two in there. It was a bit of trial and error, so I frankly don't remember the exact combination that I ended up with on each side. The basic idea was simple enough - try various combinations of shims and washers on either side until I found one that minimized play while still allowing the axle to spin smoothly. You can pick up shim packages at any LHS or online. I don't think it's necessary to fab anything. Hope that helps. :thumbsup: | |
10-21-2014, 07:09 PM | #22 |
Rock Crawler Join Date: Mar 2012 Location: bel air
check the mesh the same as you do on a 1:1, paint the ring gear and keep shimming until you get even wear in the paint
10-22-2014, 05:42 AM | #23 | |
Newbie Join Date: Jul 2012 Location: Connecticut
In other news RC4WD got back to me. They want pictures and a recepit. Hopefully after that I will get some new parts... | |
10-27-2014, 04:45 PM | #24 |
Newbie Join Date: Aug 2013 Location: Baltimore
I installed the new gears, and my Trail Finder is now rock solid. I've ran it pretty hard over the last couple of days, going through the gears on various terrain, and it seems as tough as nails. Worth mentioning....the new gears are machined from solid steel, not multi-piece, pressed together. Maybe I got an early run TF2?? |
10-27-2014, 07:36 PM | #25 |
Rock Crawler Join Date: Sep 2009 Location: Spring, Texas
Good to know! Mine is the RTR version and I just opened it to grease the gears, so I hope mine is one solid piece.
10-27-2014, 08:35 PM | #26 | |
Mike | |
12-28-2014, 06:22 PM | #27 |
It's been 2 full months since I got my TF2's transmission gear issues sorted, and I've run the truck fairly hard since then. We had an especially intense trail run this past Friday which included a LOT of rock crawling, some full speed runs in 2nd gear over rugged terrain, and a few stretches of axle deep stream crossing. The Trail Finder handled it ALL like a champ. I feel that if something in the trans was going to let go, it would have happened during this run. Dare I say, I'm contemplating ANOTHER TF2 build? Tower Hobbies has had multiple restocks of the TF2 since I purchased my "problem child", so I feel as though I'd certainly get a most recent release of the truck if I were to order one from them. Wish me luck! Mike F |
12-28-2014, 06:41 PM | #28 |
Newbie Join Date: Nov 2013 Location: Colorado Springs
Got my first TF2 in the last month and had a rear axle housing that was not right, the front pinion needed quite of shimming, and a low gear that had substantial surface imperfection that caused the truck to VERY loud. They took care of me, but I too was concerned about what was going on with rc4wd, you always nothing but good things about them. Hopefully they get things figured out.
12-28-2014, 07:44 PM | #29 |
Do it! I've put mine through the paces, shifting the tranny very regularly, and even let my 5-year old have at it for 2 hours, and it's been solid as a rock. I'm likely to do a SWB build later this year.
07-30-2015, 02:25 AM | #30 | |
Newbie Join Date: Nov 2014 Location: usa
03-01-2017, 07:28 AM | #31 |
| Re: Brand New RC4WD Trail Finder 2 w/BROKEN TRANSMISSION GEAR |
03-01-2017, 09:56 AM | #32 |
03-01-2017, 11:16 AM | #33 |
Brand New RC4WD Trail Finder 2 w/BROKEN TRANSMISSION GEAR - Similar Threads | ||||
Trail Finder 2 Bad Shifting Transmission | fadi.join | Newbie General | 3 | 05-10-2014 08:22 AM |
