09-24-2015, 04:34 PM | #1 |
Rock Crawler Join Date: Jan 2012 Location: Hudsonville, MI
| RC4WD Superlift shock question - adding oil
I recently purchased a set of RC4WD Superlift shocks for my TF2 build. I'm going remove the internal spring in the shocks and fill with oil. I've read that these types of shocks will/can leak pretty bad. Are there any tips or tricks to keep these shocks from leaking oil? I was told to use green slime. Green slime actually helps keep the seals from swelling, caused by silicone shock oil. I have also heard that soaking the shock seals in shock oil overnight will help keep them from leaking. Soaking them in shock oil overnight will cause them to swell at a faster rate. If anyone has any input, I would appreciate the help! Thanks! |
09-29-2015, 02:13 PM | #2 |
Rock Stacker Join Date: Oct 2010 Location: Boonies of CT
| Re: RC4WD Superlift shock question - adding oil
If the shocks leaks it should help for the o ring to swell to stop the leak... No?
RC4WD Superlift shock question - adding oil - Similar Threads | ||||
RC4WD Superlift Dual Front Shock Mount for Trail Finder 2 | Rckcrwlr | RC4WD Trail Finder 2 | 8 | 08-25-2012 03:10 AM |
Shock Oil Question | Syd | Axial AX-10 Scorpion | 5 | 02-08-2009 07:21 AM |
question about shocks and shock oil | cmdrpopnfresh | Newbie General | 8 | 05-12-2008 03:00 PM |
Shock Oil Question for a TLT | Maitias | Tamiya TLT Crawlers | 3 | 02-17-2006 02:24 PM |
