01-29-2016, 05:13 AM | #1 |
Quarry Creeper Join Date: Oct 2012 Location: Oxford
| Damping - oil filled vs sprung for leafs
Ok, so I'm the sort of chap that feels damping should be oil filled not sprung but obviously on these rigs they come sprung. It looks like most folk are running sprung and some even full external coil overs with the leaf set up. To me it seems insane from both the scale aspect and keeping true to leafs to run the full coil overs but I'd imagine their is a significant traction advantage and the leafs are just used to locate axles in this set up. So.... I have 2 questions all in the spirit of a debate :-) : 1. What are folks thoughts on this. 2. And anyone running oil filled shocks and their thoughts. This is with respect to running leafs only! Thanks. |
01-29-2016, 05:20 AM | #2 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
Your instincts are spot on. I run mine with oil and no internal (or external) springs, and it works much better than with the internal springs (the leafs actually get to do work). The stock shocks hold oil pretty well and work fine with that type of setup, though the damping obviously isn't as good as it would be with a wider-bored shock/damper. On one of TF2s, I've used the RRD Emulsions without external springs (so they are Swampers only), and I love the setup. I'm using Superlifts without internal springs on another TF2 (so far only test runs in the yard), and Emus without internal springs on a leafed Cruiser (again only test runs so far).
01-29-2016, 07:58 AM | #3 | |
| Re: Damping - oil filled vs sprung for leafs Quote:
On a side note i presume you are running longer shocks on the fronts for better crawling ability? And are you running any drop shackles?. Thanks. | |
01-29-2016, 08:43 AM | #4 |
Quarry Creeper Join Date: Aug 2014 Location: Chilliwack
What weight oil are people running in their shocks?
01-29-2016, 09:05 AM | #5 |
Quarry Creeper Join Date: Jul 2015 Location: Hanover
I've got the Emu's on mine. Previous owner converted to 4link. I've converted the rear back to leaf. I'll eventually do the front. Black springs, with helpers. Emu's have their internal springs as of now. Did great on a short test crawl, but as of now I can only say, that the front definitely has more articulation than the rear. But I think I want to hit the reset button (as I do with all my used rigs) and convert everything back to "factory" spec. Then I'll consider upgrades/mods. I run (I believe) 60 wt, conventional oil in an SCX, trying to slow the dampening. I'll be experimenting with the factory TF2 before long, I'm sure... I want them to act like Ascender. Slow and controlled. |
01-29-2016, 09:40 AM | #6 | ||
| Re: Damping - oil filled vs sprung for leafs I started out with 30 wt originally but have been going heavier lately (50-70). Depends on the shock, leaf setup, weight of rig, personal preference, etc. Quote:
Lots more info on leaf and suspension setup options in these threads: Team RC4WD's Comprehensive Guide to the TF2 TF2 = time to push my scale envelope http://www.rccrawler.com/forum/rc4wd...ew2-rocks.html How-to convert from links to leafs on a Gelande chassis | ||
01-29-2016, 11:17 AM | #7 |
Hmm I just have a dab of oil in my shocks without springs. Filling them with oil works well?
01-29-2016, 11:30 AM | #8 |
| Re: Damping - oil filled vs sprung for leafs Very... It serves the same purpose as in coil-over shocks. The thicker the oil, the more it will dampen suspension movements by slowing the rate at which the shock, and therefore the axle, can cycle up or down. The right weight oil can make the truck less bouncy and more stable. As long as you don't overfill the shock, total suspension travel in either direction remains the same.
01-29-2016, 11:33 AM | #9 |
Rock Crawler Join Date: May 2009 Location: Welderville just south of benchviseland
First thing I did on mine was add the Gelande hoops and 90mm Emus. I'm only running the main and middle leaves.... And because I'm weird and love heavier oil, I put some Associated 5k diff oil in the shocks and yanked out the springs. I love using heavier oil in the shocks on heavy trucks. Did the same thing on my 8.7 lb Cruiser and I love how it works.
01-29-2016, 12:43 PM | #10 |
Thanks new2rocks. I have read all those threads already! I have gelande front hoops too but was still deciding on shocks and length. I was also absolutely sure on upgraded shackles initially but recently have wavered on them - also due to cost tbh. How much do these shackles compromise side sloping? And how much do they add to the height of the rig? Looks to be about 1/4". Trying to keep my rig low cog. |
01-29-2016, 01:48 PM | #11 |
I'm still on the fence on those shooter shackles and t-boxes... I know a lot of people run and like them, but the cost for what it is kind of turned me off - But that's just me. You can do the "Chino mod" to your leaves and it should add a little more give. I know Mr. Fr8cture used Bruiser shackles to help him out a little. I know if you want a lot of travel and a lower cog, you made the right move with the taller shock hoops. At least realistic travel... Cuz that's what this lovable little rig is all about!
01-29-2016, 02:07 PM | #12 |
I also chino modded my leafs. I cant stand the look of shooters so I wont be getting any. lol
01-29-2016, 02:18 PM | #13 | |
tbh the cost is just ridiculous and that's what ain't helped..... I think the other issue is that it's all good and well having your wheel being able to drop down further with these shackles but unless there is pressure from the damper, or the leaf has a very good curve, the wheel will not have 'weight' on it and provide little traction..... Which is probably also part of why a lot of folk like running springs on their dampers as it will aid traction in that manner.... And lets be honest here... They aint never gonna have a shit load of 'reliable' usable articulation like a 4 link.... But that is the beauty of these things and why i personally want to retain leafs without a doubt.... | |
01-29-2016, 08:19 PM | #14 |
| Re: Damping - oil filled vs sprung for leafs |
01-29-2016, 08:27 PM | #15 |
Looks...and points. Lol.
Damping - oil filled vs sprung for leafs - Similar Threads | ||||
Oil-filled diffs | microgoat | General Scale Talk | 15 | 02-01-2016 12:35 PM |
Who has these? RC4wd oil filled shocks | mmihm06 | General Scale Talk | 3 | 01-03-2014 09:51 AM |
Oil filled shocks on SMC + Chassis's | Savage00 | Losi Micro-Rock Crawler | 5 | 05-21-2012 07:25 AM |
losi 1/24 oil filled shocks | Positronic | Losi Micro-Rock Crawler | 4 | 08-07-2010 01:02 PM |
