03-11-2016, 09:25 PM | #1 |
RCC Addict Join Date: Jan 2007 Location: caldwell,idaho
| Rc4wd topless blazer
Sitting in a hotel in Mississippi gets really boring ,I have been here for two weeks doing controlled burns with a helicopter .i had my wife send me some of my tools and electronics .i bought a tf2 slider and everything else from rpp.When rc4wd came out with the blazer I knew I had to have one and it was going to be topless like my 73 k5.Rc4wd did an amazing job on this body and the details are over the top I just wish they would also come out with a 71 k5 blazer any way here you go. [IMG]http://i259.photobucket.com/albums/hh305/warriorsimi/image_3.jpeg[/IMG [IMG]http://i259.photobucket.com/albums/hh305/warriorsimi/image_2.jpeg[/IMG |
03-11-2016, 09:28 PM | #2 |
| Re: Rc4wd topless blazer |
03-11-2016, 10:32 PM | #3 |
RCC Addict Join Date: Feb 2014 Location: Mt. Juliet, TN
Looks good, have you thought about a rollbar of some sort to protect the winshield area in the event of a rollover?
03-12-2016, 11:43 PM | #4 |
Yes I will be building a roll bar for it but probably not till I get home in May.i need to find a light kit for it and do something about the gap in the floor.
03-13-2016, 06:15 AM | #5 |
Rock Crawler Join Date: Dec 2008 Location: Fortuna Calif.
I am thinking abut doing the same, I had a 74 1:1 myself. Stock it had a cheesy factory "roll bar". And a simple rear seat, yours looks very nice. And the local Hobby Shop has two in stock |
03-13-2016, 08:39 AM | #6 |
RCC Addict Join Date: Dec 2009 Location: Laceys Spring, Alabama
Those Trail Blades look great on there.
03-13-2016, 10:46 AM | #7 |
Thanks ,I hope they don't rub too much I had to go a different route to mount the body to clear the tires.it is mounted to the front and back using the bumpers and the chassis mounts that you are suppose to remove.
03-15-2016, 01:09 PM | #8 |
can somebody that has the scale v8 in their truck tell me if its works good ? is it geared down low enough ? thanks.
03-15-2016, 02:12 PM | #9 |
| Re: Rc4wd topless blazer I don't have the V8 but just running the numbers through a gearing calculator says the R4 trans results in about 1 mph more in top speed than the stock trans in low gear and about 3 mph less than high gear (based on a 35T on 2S in a stock truck). So it is a little more than low gear of the R3 but much lower than high gear if that is the range you are looking for.
03-15-2016, 05:22 PM | #10 |
that almost sounds like a good set up ,I wont know until I run my truck as is.i want to build this rig as scale as I can possibly build it including the v8 and r4 trans also thinking on the engine sound machine from associated.thanks for your help.
03-15-2016, 07:44 PM | #11 |
got a little more work done ,I need to find a rear seat for it I think that will give it the real blazer look. |
03-15-2016, 07:47 PM | #12 |
03-15-2016, 08:05 PM | #13 |
I changed out the foams today also the lug bolts. |
03-15-2016, 08:21 PM | #14 |
Quarry Creeper Join Date: May 2010 Location: Kaena Point, Hawaii
looks good |
03-15-2016, 08:44 PM | #15 |
Great looking rig, those foams really changed the looks of your tires. What hubs/wheel nuts are you using? Last edited by Big Bill; 03-15-2016 at 08:46 PM. |
03-16-2016, 06:23 AM | #16 |
I am using rc4wd wideners and g made bolts for the wheel nuts.
03-18-2016, 07:25 PM | #17 |
took it out for the first time and it did really good but I am not liking how high it looks and the tires rubbing .I took the wideners off before the run and it did roll over a couple of times until I learned how to drive it gonna have to look into smaller tires and maybe 1.55.or what do you guys think ? Last edited by warriorsimi; 03-18-2016 at 07:28 PM. |
03-18-2016, 11:28 PM | #18 |
damn, looks good putting in work |
03-21-2016, 11:25 AM | #19 | |
| Re: Rc4wd topless blazer Quote:
Yes, it does! | |
03-21-2016, 06:59 PM | #20 |
the other day when I took the blazer out I forgot to mention that I had some music running while driving whichi thought was really cool,and today I found another speaker for about 10 bucks.heres a pic of the first speaker found and the one in the rear I found today .you cant play both though which sucks. |
Rc4wd topless blazer - Similar Threads | ||||
The Chop Shop- 1990 Class 1 Topless K5 Blazer | Hoosierdady | 1.9 Scale Rigs | 210 | 04-05-2016 02:49 PM |
Clod Body Chevy Blazer: Fully Topless | ah_5500 | 1.9 Scale Rigs | 37 | 10-02-2014 05:13 AM |
c10 to topless blazer | braceysdad | 2.2 Scale Rigs | 76 | 08-23-2006 04:11 PM |
