03-30-2017, 10:39 PM | #1 |
Rock Stacker Join Date: Feb 2017 Location: United States
| Filling stock shocks with oil
Has anyone taken the stock Ultimate Scale shocks, removed the springs and filled them with oil? If so, what weight of oil did you use and how are they holding up? I thought about doing this.
03-31-2017, 06:18 AM | #2 |
| Re: Filling stock shocks with oil
I did that for my cousin's truck and they worked pretty good with 5K diff oil. None of the actual shock oils I tried were heavy enough to produce adequate damper action in such a small bodied shock. He ran them for a few months then the upper bushings fell out on 3 of the shocks and that was the end of the stockers. |
03-31-2017, 07:19 PM | #3 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
Just as svt923 says...diff oil works best in them (3k or 5k). The bushings do tend to wear out relatively easily, but if you're industrious, you can glue (or JB Weld) them back into place to get more life out of them.
04-01-2017, 03:48 PM | #4 |
Quarry Creeper Join Date: Feb 2017 Location: Adirondack Park
| Re: Filling stock shocks with oil What is a longer lasting shock to replace them. Nothing fancy just long life quality shocks.
04-02-2017, 09:25 PM | #5 |
There are plenty of good shock choices. Among relatively narrow-bodied shocks, I've had good luck with the RC4WD RRD Emulsions and Proline Scalers. Both can take plenty of abuse and perform well with the right setup. Assuming you're still running the leafs, those can (and should) be run without coil springs.
Filling stock shocks with oil - Similar Threads | ||||
oil filling in piggyback shocks? | v4impactor | Newbie General | 9 | 02-27-2021 09:04 PM |
For those that run stock shocks with no oil ... | TakeOffYouHoser | Axial SCX-10 | 60 | 01-18-2015 06:46 PM |
Stock Shocks, No Oil? | Freakshow185 | Axial Wraith | 3 | 05-17-2013 01:44 PM |
Filling Stock shocks | Churb | Redcat Crawlers | 5 | 05-18-2012 06:44 AM |
BEST Shock oil weight in stock shocks | autumnsummers1 | Axial AX-10 Scorpion | 10 | 02-09-2009 11:18 PM |
