Thread: EMU vs Superlift
Old 10-07-2017, 11:01 AM   #1
Default EMU vs Superlift
Are the Old Man EMU's and the Superlift's basically the same shock, just different color and label?
I am going the route of internal spring removed 90mm front with Geoland loop and either 90 or 100mm in the rear on my TF2 regular cab.
Is there a reason to pick 100 over the 90mm for the rear? I have not started the build, it is still in the box so just planning. I do see where the EMU's don't come in a 100mm, just the Superlift's...
Thanks,
GR8 PMKN is offline   Reply With Quote
Old 10-09-2017, 02:17 AM   #2
Default Re: EMU vs Superlift
The Emus and Superlifts are basically the same except for color/graphics and available sizes. As for rear shocks, there's no reason to use 100s in the back. You won't get any extra usable travel out of it, so 90mm is fine. Good luck with your build!
new2rocks is offline   Reply With Quote
Old 10-09-2017, 07:53 AM   #3
Thank you. I was hoping you would reply. I have been following your advise on JatoTheRipper's build. I need to finish my SCX10-2 build before I start this one or neither one will ever get finished.
EMU vs Superlift - Similar Threads
emu´s seriesIII lookalike emu 1.9 Scale Rigs 11 03-02-2016 03:12 AM
Old Man Emu shocks B94Cast General Scale Talk 9 10-16-2013 07:33 PM
New old man emu shocks adamargue General Crawlers 5 09-13-2013 06:04 AM
