Thread: Imthatguy's Top 5 Leaf Spring Mods
Old 01-18-2018, 05:45 AM   #1
Sinking with the ship
1BadJeepBruiser's Avatar
Default Imthatguy's Top 5 Leaf Spring Mods
For those who haven't seen it, Matt took the time to explain how to get the max amount of performance out of your TF2
https://www.youtube.com/watch?v=q4rtpjY4fAw&t=229s
Old 01-18-2018, 08:29 AM   #2
Default Re: Imthatguy's Top 5 Leaf Spring Mods
Great vid, i landed on it a few days ago during my TF2 suspension YouTube crawl =)
Digital is offline   Reply With Quote
Old 01-18-2018, 01:44 PM   #3
Moderator
JatoTheRipper's Avatar
Great video for sure.
Old 02-03-2018, 09:50 PM   #4
Hmm no mention of the easy o-ring mod
one of the quickest and easiest ways to get flex from stock
afrofroggy is offline   Reply With Quote
Old 03-20-2018, 12:08 PM   #5
o-ring mod? whats that one
m1009cucv is offline   Reply With Quote
Old 03-26-2018, 12:35 AM   #6
undo bolts that hold the leafs onto the diff (you may need longer bolts)
small oring (number 6 i think they are) on the diff side then re-install the springs but before you put the nylock nuts on put another oring on-top of the spring now snug the nuts back up not too tight just firm flex will be more than double in most cases
Old 01-25-2019, 01:26 PM   #7
Good tips to know. I plan on doing everything except Chino mod. As I rebuild this leaf sprung beast. And getting the G2's front shock towers
Sent from my FRD-L14 using Tapatalk
Schs2013 is offline   Reply With Quote
Old 04-12-2019, 02:05 AM   #8
Can I ask if the suspension tips and mods for a TF2, will also work for a GCN 4 Ten chassis that uses RC4WD leaf springs and RC4WD Toyota axles
kgb424 is offline   Reply With Quote
Old 04-12-2019, 04:21 AM   #9
Yes, the chino mod and many of the other tips pretty much apply to all leaf sprung trucks
Old 04-12-2019, 11:21 PM   #10
Thank you for input, now the problem is none of my RC4WD 1.9'' Pro 10's wheels and my 1.9'' RC4WD 6 lug Wagon Wheels, the tires due not clear the linkage that connects both steering knuckles, I'm guessing I will have to buy some new aluminum 1.9'' SLW wheels, I'm thinking I will need the 350 mm or the 475 mm hubs, I seen RC4WD makes +7 mm wheel spacers for RC4WD wheels but the Proline TSL Super Swampers with C.I. foams will not mount on the steel RC4WD steel wheels, So I will have to check out wheels, the RC4WD steel wheels work fine on my original SCX10 and my 1.9'' Wraith, it must be the width of the Toyota axles compared to the width of the original SCX10 axles
Old 01-24-2020, 03:02 AM   #11
Good thing about the leaf spring, I made all the modifications in my Blazer Special Edition and I needed it, thank you partner for sharing.
FREEDOM83 is offline   Reply With Quote
Old 01-29-2020, 06:50 PM   #12
Not entirely sure how well you can see in the photos but instead of o rings for the "o ring mod" I have modified some small hinges to fit between the axle housing and the underside of the leaf springs, made the countersunk areas larger with the trusty dremel so the heads sit down.
As the wheel drops and the angle of the axle changes the hinge opens up to allow the spring to stay flatter.
This gives me full shock extension with 100mm Bilstein rears and the original 90mm rears in the front using Gelande 2 front shock hoops set behind the front axle.
Also have the Terraflex shackles in the rear mounted upside down and backwards, for some reason they work best for my rig this way, they don't collapse onto the spring under compression but tuck up towards the chassis out of the way.
Sent from my SM-A530F using Tapatalk
fourocker is offline   Reply With Quote
Old 05-11-2020, 05:30 PM   #13
What size/length shocks do you have? The stock 80, 90 or 100 mm? I am trying to see if I will need new suits once I have completed all my mods. I will be using the same car of spray paint for comparison
Scrmblr2 is offline   Reply With Quote
Imthatguy's Top 5 Leaf Spring Mods - Similar Threads
Leaf spring kits and spring rates BansheeManiac Axial SCX-10 2 09-22-2010 02:23 PM
