02-23-2018, 06:58 AM | #1 |
Rock Crawler Join Date: Apr 2017 Location: US
| Yota1 axles?
So i want to try to keep the yota1 axle assembly for now that came stock on the tf2. But it's obvious that the yota1 axles are limited in there throw/angle of turning. Is it worth picking up a set of the xvd axles for the yoto1 to improving steering from 32 to 36.5 degrees? Or is it better just to spend the money on the yota2 axles with xvd axles with it?
02-23-2018, 10:59 AM | #2 |
Newbie Join Date: Apr 2012 Location: Stockton
| Re: Yota1 axles?
In my opinion the XVD’s will give you the turning radius. I bought a Yota-ll front axel thinking I was going to get the radius of my Marlin and I had to buy the XVD’s in addition later to get the radius like the Marlin after realizing later that the Marlin came with XVD’s installed in the Yota-ll axel. I strongly believe that you can just get the XVD’s and save money. Sent from my iPhone using Tapatalk |
02-23-2018, 12:27 PM | #3 |
| Re: Yota1 axles?
Thanks that what I was kind of hoping for. Guess I could spend a little more if I had to. But I've got way too much money already in this truck, it will be worth it I believe. I've got the xvd axles on the wish list. So now I guess I'll gave to order some in. I feel if I don't change the turning radius it will be a disappointment in that area.
02-24-2018, 07:36 AM | #4 | |
Quarry Creeper Join Date: Oct 2012 Location: Oxford
| Re: Yota1 axles? Quote:
I added xvds to my yota1 axles and definitely noticed the difference. It is still not great steering but i have also flipped the transfer case for overdrive in the front axle. Between these 2 mods it will certainly make most corners as well as a standard scx10 with no overdrive. | |
02-24-2018, 12:52 PM | #5 |
| Re: Yota1 axles?
I wonder how much of a angle the yota2 axles have. Any one have any before and after pictures of the steering angle anything?
02-24-2018, 01:01 PM | #6 |
| Re: Yota1 axles?
A simple google search will help you out. Forum posts and videos. First return is the RC4WD forum and breaks it down. |
02-24-2018, 04:54 PM | #7 |
| Re: Yota1 axles? |
02-24-2018, 08:54 PM | #8 |
| Re: Yota1 axles?
No worries. I tend to migrate to google and google image searches first. I can usually dig up something with a few different search terms.
02-24-2018, 09:01 PM | #9 |
| Re: Yota1 axles?
Well still digging for info. Came up with 45 degrees for the yota2 axles, for sure bets the yota1 axles with the xvd axles at 36.5 degrees. Assuming that info is correct. Guess I'll keep digging for more info. Maybe even think more about the yota2 axles and just do it.
02-24-2018, 09:10 PM | #10 |
| Re: Yota1 axles?
You may know but the yota 1 axles and to some extent the yota 2 need shimming to make a better ring/pinion gear mesh. Definitely the yota 1’s, in my experiences at least.
02-24-2018, 10:21 PM | #11 |
| Re: Yota1 axles? Thanks for the tip. But yes I know about shinning the axles and shimmd them before I started assembly of the truck. So many parts and decisions, what to do. At this point it just doesn't matter how much more I dump in this project what's a little more money I guess.
02-25-2018, 07:48 AM | #12 |
Pebble Pounder Join Date: Mar 2016 Location: GC
| Re: Yota1 axles?
Yota 1 has enough steering angle to rub tires on leaf springs or links if using stock hexs and wheel backspacing. A small diameter tire or widening track width is gonna be needed to really use more steering.
02-25-2018, 04:27 PM | #13 |
| Re: Yota1 axles?
Just to add to this. Today i went to a comp and a chap there had a marlin. Now my yota 1 axles have xvds and i've grinded them a wee bit and as the above post we are limited by leafs without further wheel offset anyway. Oddly, side by side there looked to be no difference at all in steering angle. Or certainly not 5/10 degrees... So not sure if again this lack of angle is due to the leaf situation. If i'm honest i run mine so it touches the leafs at full lock - there's soo much play in my leaf set up it would be severely limiting not to- where as his had a good gap on full lock and he mentioned he set it up safe... If the printed data is correct then this all adds up. And to get full use of this increased angle we need to use a higher offset wheel or hub. "thumbs" I'm pretty sure i'll be investing in a marlin shortly so i shall confirm this if it happens... |
