Thread: Ar44
Old 07-28-2018, 10:06 AM   #1
Default Ar44
I Have never fallen in love with the TF2 had a few but just never clicked. Very scale and cool rigs that i wish i could find love for. Long story i have one on the shelf.
Being an Axial fan i was told to check out JEC racing. next thing i know i have leave mounts ordered for the AR44. and being i dont have extra AR44s a set was also somehow ordered. Dont know how all that buy it now happened?!?!?!
Im sure someone has done this set up. Im looking or some pics, info, the good the bad the ugly!! So im ready when the how did these parts get here.
Thanks ahead of time and yes ive used the search button with no luck.
hotrodsoup is offline   Reply With Quote
Old 07-28-2018, 12:09 PM   #2
Default Re: Ar44
A&M garage on facebook has a few set up on ar44 curries. I'm sure setup translates to stock housings too.
fr8cture is offline   Reply With Quote
Old 08-20-2018, 03:59 PM   #3
Default Re: Ar44
My JEC Racing alumn leaf spring mounts for the AR44 will be here this week along with the leaf springs and shackles. I'll post here with the mounting process once complete.
xtreme4x2 is offline   Reply With Quote
Old 08-20-2018, 07:40 PM   #4
Default Re: Ar44
These aren’t going on my TF2 but here’s my SSD Pro44’s with the JEC Racing leaf mounts. Hope that helps in some regard. These are RC4WD leafs so should bolt right up!
LSXGMC is offline   Reply With Quote
Old 08-20-2018, 10:09 PM   #5
Default Re: Ar44
Check my latest build, Marlene Cwalrer.
imthatguy is offline   Reply With Quote
Old 08-27-2018, 11:41 AM   #6
Thumbs up Re: Ar44
My setup with the JEC brass mounts. Took the overload leaf out and am running 3 leafs. Still seems kinda stiff.
I grinded down the side of the spring perch and am also running stock rear shocks with 50wt and no springs. I might go down to 2 leafs and get the 90mm rc4wd internal spring shocks.
I also added spacers to push the front mounts away from the frame so its even with the shackles.
How is everyone else setup?
Ar44 - Similar Threads
ar44 in different widths Dezertdirt Axial AX-10 Scorpion 1 07-18-2018 12:56 AM
AR44 screws Motorider Axial SCX10 II 11 11-10-2017 03:11 PM
