10-11-2020, 02:52 PM | #1 |
Pebble Pounder Join Date: Nov 2006 Location: Tennessee
| R3 Spur compatibility...HH 2700kv to fast
Hey guys I got a HH Puller Pro and went with a 2700kv because I had used a 2850kv Slate before on a Ax2 Rc4wd trans in a tube crawler and loved it but that trans must of had a lower ratio. My Marlin TF2 is just to fast and low speed crawling sucks. So I am looking for a larger spur than the 64t that is on it. I already dropped down to a 12t pinion and hate to go smaller because I was worried about tooth engagement. So I was wondering if anyone had used a larger spur and if so which one. |
10-11-2020, 04:53 PM | #2 |
Pebble Pounder Join Date: Aug 2020
| Re: R3 Spur compatibility...HH 2700kv to fast
Are there under drive gears available for your axles? Sent from my iPhone using Tapatalk |
10-11-2020, 05:37 PM | #3 |
No unfortunately they dont offer under drive gears for the Yota II axles. I went by the hobby shop and picked up a 10T pinion gear and it seemed to help. My biggest complaint is the low speed startup. It has a slight cogging when I try to crawl as slow as I can. I was at RRW Krawlzone yesterday and for the Mountains are Krawling event and it started raining on us first thing in the morning and my Flysky GT5 got wet and I had had issues with it. So I put my original radio that came with my Marlin TF2 and the resolution of the throttle band may just not be as good as the GT5 was. I also need to hookup my Mamba X to the Castle Link and go through the settings and double check everything. I also need to probably adjust the throttle curve and see if that will help some. |
R3 Spur compatibility...HH 2700kv to fast - Similar Threads | ||||
Mamba X 2700kv on 4s? | Oh How Original | Electronics | 6 | 02-04-2020 03:02 PM |
Puller Pro - 2200KV 4S or 2700KV 3S? | ajsmcs | Axial SCX10 II | 67 | 02-15-2017 12:18 PM |
Running a new PP 2700kv....gearing? | rngrchad | Axial RR10 Bomber | 2 | 06-26-2016 09:01 AM |
Holmes 2700kv | Jimbow | Vaterra Ascender | 0 | 05-10-2015 03:42 PM |
Exo spur gear compatibility | U F'n A Racing | Non Crawler RC's | 0 | 11-18-2013 10:42 PM |
