11-24-2020, 10:27 PM | #1 |
Quarry Creeper Join Date: Dec 2015 Location: Norway
| Axle upgrade
My old worn out tf2 Yota front axle need some tlc. Is it a better idea to just buy a new complete axle? If so what would be a nice upgrade from the Yota axle? The Yota 2? Boomracing brx90? Are there other axles that would fit? |
12-11-2020, 06:25 AM | #2 |
Newbie Join Date: Feb 2016 Location: indonesia
| Re: Axle upgrade
I hope this help |
12-11-2020, 03:36 PM | #3 |
| Re: Axle upgrade
Thanks. I’ve orderd a set of Brx90 axles.
12-13-2020, 06:34 PM | #4 |
Quarry Creeper Join Date: Aug 2009 Location: orange county
| Re: Axle upgrade
Are the k44 axles anymore durable than the yota or yota 2. I’ve got a couple of knuckle bolts that keep stripping and I’m getting tired of them doing this. Housing wise are they any better.
12-13-2020, 10:19 PM | #5 |
| Re: Axle upgrade
I've had decent luck installing m3 helicoils in the kingpin screw holes on my Yota2's. I must have broken 3 or 4 helicoils in the process of installing 4, but the stainless steel threads hold much better than the butter-soft potmetal of the stock housings. Better than new for less money than a replacement housing.
12-14-2020, 07:13 AM | #6 |
| Re: Axle upgrade
Do those boom racing axles actually steer that sharp without binding the Ujoints? If so, that's impressive. Next question, what's the max size tire you can run without all the angle allowing the tire to kiss the leaf springs?
12-18-2020, 12:10 AM | #7 | |
| Re: Axle upgrade Quote:
I dont know the maximum steering of this axle, but i limit the throw with stopper that came with the axle.. i run rc4wd patagonia scale 4.1 tires that pretty wide tire for me. | |
12-27-2020, 10:04 PM | #8 | |
12-28-2020, 04:19 PM | #9 |
| Re: Axle upgrade
There's other options out there, but this is the one I used: https://www.amazon.com/Z-SK40210-Thr...read+re&sr=8-7 |
12-29-2020, 05:44 PM | #10 |
| Re: Axle upgrade
Perfect thank you that’s what I was looking at
12-31-2020, 05:29 PM | #11 | |
01-04-2021, 09:41 AM | #12 |
| Re: Axle upgrade
Got my Brx90 axles mounted and trail tested. The gearing is now way to low for my taste. What gearing do you run with Brx90/ar44 axles on the trailfinder?
01-04-2021, 11:24 AM | #13 |
Rock Crawler Join Date: Jun 2018 Location: Orange County, CA
| Re: Axle upgrade No. I have the K44's on my TF2 and I feel they are just as bad if not worse than the stock ones.
Axle upgrade - Similar Threads | ||||
Best scx10 Axle/Housing Upgrade and trans upgrade | Rav3n | Axial SCX-10 | 10 | 09-07-2019 09:47 PM |
axle upgrade | Rockwolf58 | G-Made Crawlers | 1 | 03-18-2014 10:08 PM |
axle upgrade soon! | bowsher925 | Newbie General | 9 | 02-15-2014 04:50 PM |
axle upgrade | jordanator62 | Tamiya Txt-1 and Juggernaut | 2 | 06-17-2004 11:22 AM |
