Go Back   RCCrawler Forums > Vendors > RCP Crawlers
Thread: Titanium Shafts
Old 05-09-2013, 04:58 PM   #1
RCP CRAWLERS
ZoSo's Avatar
Default Titanium Shafts
TITANIUM TOP & IDLER SHAFTS for the Axial transmissions
Designed by Don Hughes AKA mjyjxj
The shafts are made of 6AL4V surgical grade titanium
commonly known in the industry as 6/4 and is made in the USA.
The top shaft is used without the slipper clutch and works
in conjunction with 3 racing's PN# 3R/AX10-02/GR or stock axial #ax80009
Lower CG
Less Rotating Weight
Longer Run Time
*TITANIUM*TOP*&*IDLER...
ZoSo is offline   Reply With Quote
Old 05-09-2013, 09:32 PM   #2
Default Re: Titanium Shafts
Very nice products. How much does the top shaft weigh? In grams..
Thanks
Hittman is offline   Reply With Quote
Old 05-09-2013, 09:55 PM   #3
If I remember right I weighed mine and I believe it was 2-4 grams for both shafts
boosted4lyf is offline   Reply With Quote
Old 05-10-2013, 01:14 PM   #4
Which outputs are those
ittybitty is offline   Reply With Quote
Old 05-10-2013, 03:59 PM   #5
RCP CRAWLERS
ZoSo's Avatar
for use in the AX-10, SCX-10 and Wraith transmissions
Old 05-10-2013, 04:39 PM   #6
I think you misunderstood him...
Calderwood is offline   Reply With Quote
Old 05-10-2013, 06:03 PM   #7
RCP CRAWLERS
ZoSo's Avatar
Oh I think your right ...that was some custom fab work by DelMonte
Old 05-10-2013, 09:53 PM   #8
Nice work indeed
Old 05-11-2013, 11:50 PM   #9
Y-Town Crawlers
Del Monte's Avatar
Yep
I installed my Ti shafts last weekend. Great parts, thanks Don!
Del Monte is offline   Reply With Quote
Old 05-12-2013, 03:48 PM   #10
So is the announcement right, wrong or what???
Hardline is offline   Reply With Quote
Old 05-13-2013, 05:06 PM   #11
RCP CRAWLERS
ZoSo's Avatar
The question was about the output unit
it's been cutaway, to lighten it up.
The titanium shafts work great!
Old 06-24-2013, 09:46 AM   #12
RCP CRAWLERS
ZoSo's Avatar
The titanium shafts are back
Old 06-27-2013, 02:22 PM   #13
RCP CRAWLERS
ZoSo's Avatar
back in stock
Old 07-26-2013, 12:45 PM   #14
TN State Champ 11,12,13
Pdog7's Avatar
This statement is confusing as they are totally different parts and it says it will work with either.....
Is it supposed to work in conjunction with both parts?
One is a spur gear adapter and the other the stock plastic transmission housing.
I ordered the shafts, but now wonder if I need the adapter also?
Pdog7 is offline   Reply With Quote
Old 07-26-2013, 02:39 PM   #15
I've got a STUBBY!
Joshie's Avatar
the axial ax80009 comes with a plastic spur carrier/ slipper elim in the kit. which does the same thing as the 3racing part.
not sent from an ifail.
Joshie is offline   Reply With Quote
Old 07-26-2013, 02:50 PM   #16
Pdog7's Avatar
Thanks
Old 07-26-2013, 03:43 PM   #17
RCP CRAWLERS
ZoSo's Avatar
thanks Joshie
Old 10-15-2013, 06:13 PM   #18
Any plans on producing these again? I need them badly for my sporty build
Thanks,
Farmer
Farmer is offline   Reply With Quote
Old 10-16-2013, 06:10 PM   #19
RCP CRAWLERS
ZoSo's Avatar
Thanks,
Farmer
yes.... I'll let you know when they are ready
Old 11-01-2013, 10:11 AM   #20
Could you give me a ballpark of when these will be ready? I really need an idler shaft but if these are going to be coming back out in the next 4-6 weeks I could hold off.
Thanks for any info you can share.
ninja turtle is offline   Reply With Quote
Titanium Shafts - Similar Threads
titanium tlt shafts supercrawlerfreak Chit Chat 70 10-22-2006 04:54 PM
You may edit your posts
