Go Back   RCCrawler.com Bulletin Board > Vendors > RCP Crawlers
Thread: ***Integy Aluminum Gear Case for Clod***
Old 03-21-2007, 04:48 PM   #1
Rockpiledriver's Avatar
Default ***Integy Aluminum Gear Case for Clod***
Team Integy has just released this affordable aluminum gear case for the clod. This thing is perfect for high power brushless motors, like the Hyperions, and the Novak Crawler system that are capable of splitting a stock plastic case in 2. It is designed to work with stock parts, so all currently available aftermarket products should work also.
Another possible advantage of this case is weight down low and centered in the rig.
Price .... $34.99 ea
http://www.rcpcrawlers.com/clod_axles.html
Rockpiledriver is offline   Reply With Quote
Old 03-21-2007, 06:19 PM   #2
Gold Star Baby!
DISTURBIN' tha PEACE's Avatar
Wow, that's cheap. Makes my JPS cases seem like a rip.
They look cast, that's prollie why.
DISTURBIN' tha PEACE is offline   Reply With Quote
Old 03-21-2007, 10:30 PM   #3
Just having Fun Again
Red Rockcrawler's Avatar
I can see another purchase coming soon for these and another set of bead locks.
Red Rockcrawler is offline   Reply With Quote
Old 03-22-2007, 07:52 AM   #4
Now all integy needs to make is cheap clod knuckles and axle tubes
Brandon M is offline   Reply With Quote
Old 03-23-2007, 06:39 AM   #5
put 2 of these on hold. still figuring out what else im buying from you so i can get it all in one order.
davway is offline   Reply With Quote
Old 03-23-2007, 08:35 AM   #6
Haters gonna Hate
1BadJeepBruiser's Avatar
WOW thats a deal and a half, those would look good anodized black
Old 03-23-2007, 08:40 AM   #7
ive been waiting to build a clod based crawler to find some cheap axles, with these out now i think instead of buying i'll just get the parts together and build some bullit proof axles.
X2 1BJB!
Thorsteenster is offline   Reply With Quote
Old 03-23-2007, 02:46 PM   #8
Thumbs down
I would be very weary of integy aluminum . I know in the racing scene they are the bottom of the barrel.
PROTOTYPE is offline   Reply With Quote
Old 03-23-2007, 03:44 PM   #9
What's with the thumbsdown? Have you even seen one of these? Used one?
Or are you just bashing a product that you have no experience with? It's a gear case not a suspenion part. The ones I saw looked very nice. I will run them with absolute confidence. Would you expect the plastic to be stronger?
Old 03-23-2007, 04:23 PM   #10
hunter306's Avatar
Some of their alum. was suspect, but that was the earlier stuff.
Alot of the new Type III stuff is actually pretty solid considering the price-tag. Now whether or not it holds up to extreme abuse, that's another story.
hunter306 is offline   Reply With Quote
Old 03-25-2007, 12:52 AM   #11
TCS/Holmes Hobbies
SVEN's Avatar
Very nice price indeed.
Do you have any idea if Integy plans on making axle tubes (affordable, like these cases)?
SVEN is offline   Reply With Quote
Old 03-25-2007, 02:18 AM   #12
666
666's Avatar
I wish I could find my camera, this is cool!
666 is online now   Reply With Quote
Old 03-25-2007, 02:41 AM   #13
i checked out Integys site and couldnt find any alloy/aluminium tubes.
send them an email and ask.
Old 03-25-2007, 07:58 AM   #14
being cast alu, what do you think the impact strength will be? brings to mind doing an engine swap on my old 73 honda CB550 and smacking the cast alu somthing or other and it breaking fairly easily. it was the one coming out
Old 03-25-2007, 02:56 PM   #15
OCCUPY RCC!
dezfan's Avatar
The price is awesome!
The weight will also be an advantage, you don't happen to know what they weigh do you?
My only concern would be how well the the aluminum will slide on the rock compared to the stock plastic.
Also it may be difficult to grind off the mount for the stock Clod bumper and the location on the lower front were the case bolts together, they get hung up quit a bit if they are not removed?
If these turn out to be a success, I hope Integy brings more crawler oriented parts to market!
dezfan is offline   Reply With Quote
Old 03-25-2007, 06:13 PM   #16
I joined the Band!
all of integys stuff has great prices and it would be great if they did release more crawler parts...hopefully alum. beadlocks!!!
rockwar is offline   Reply With Quote
Old 03-26-2007, 11:41 AM   #17
666
666's Avatar
Would u like me to bust out the scale?
Old 03-26-2007, 11:53 AM   #18
OCCUPY RCC!
dezfan's Avatar
Well hellz yeah!
Old 03-27-2007, 04:15 AM   #19
price is dirt cheap seen it on there site i thought it was a typo. does it have the cut out for adjustable motor like the rest or just 2 holes like the stock clod ones
andrewmp6 is offline   Reply With Quote
Old 03-27-2007, 06:27 AM   #20
being it only has 2 holes on this side, im guessing it only has 2 on the other side of the nonadjustable type hole.
You may edit your posts
