12-27-2009, 07:08 PM | #1 |
Pebble Pounder Join Date: Dec 2009 Location: roy
| redcat battery
does anyone know how long to charge the stock battery? The charger doesn't have a light or any instruction in the manual.
12-27-2009, 08:36 PM | #2 |
Pebble Pounder Join Date: Oct 2009 Location: northridge
Just plug it in an let it charge for about 6 hours. |
12-27-2009, 08:55 PM | #3 |
Pebble Pounder Join Date: May 2007 Location: Little Rock
really? mine only takes about 25 mins on a decent charger. Your manual also states that you should Never charge you battery over 5-6 hours.
12-28-2009, 09:24 AM | #4 |
thats the thing no way of telling. will be switching it over so i can use my dynamite charger
12-28-2009, 09:36 AM | #5 |
RCC Addict Join Date: Jul 2009 Location: Blacksburg, VA
The stock charger isn't that good anyway. Even if you charge the battery for about an hour, I was only getting 15 min runtimes at most. On a better charger I get almost 45 mins on it.
12-30-2009, 11:49 AM | #6 |
Pebble Pounder Join Date: Dec 2008 Location: Eastern, Oregon
It's a 1500mah battery (milliamp/hour) and the charger is a 500mah so, the math says 3 hours. Upgrading the battery is one of the best things you can do to these rigs, even useing the same size battery with good quality cells will increase your run time quite a bit.
12-31-2009, 12:44 AM | #7 |
changing battery as soons as possible so I can run my ax10 and recat with the same batteries.
12-31-2009, 02:32 PM | #8 |
Rock Stacker Join Date: Nov 2009 Location: Killingworth
1) Change to the Tenergy 3800mah square battery - DO NO use a stick battery and there is no real need for splits. 2) Go to NitroRCX and pick up a ExceedRC charger 51C00-AC-Charger w/indicator light for all of $4 plus shipping. They work quickly and dependably.
