Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Redcat Crawlers
Thread: redcat battery
Old 12-27-2009, 07:08 PM   #1
Default redcat battery
does anyone know how long to charge the stock battery? The charger doesn't have a light or any instruction in the manual.
motojeep is offline   Reply With Quote
Old 12-27-2009, 08:36 PM   #2
Just plug it in an let it charge for about 6 hours.
landrover4wd is offline   Reply With Quote
Old 12-27-2009, 08:55 PM   #3
really? mine only takes about 25 mins on a decent charger. Your manual also states that you should Never charge you battery over 5-6 hours.
house_Fly is offline   Reply With Quote
Old 12-28-2009, 09:24 AM   #4
thats the thing no way of telling. will be switching it over so i can use my dynamite charger
Old 12-28-2009, 09:36 AM   #5
The stock charger isn't that good anyway. Even if you charge the battery for about an hour, I was only getting 15 min runtimes at most. On a better charger I get almost 45 mins on it.
jsowens is offline   Reply With Quote
Old 12-30-2009, 11:49 AM   #6
It's a 1500mah battery (milliamp/hour) and the charger is a 500mah so, the math says 3 hours. Upgrading the battery is one of the best things you can do to these rigs, even useing the same size battery with good quality cells will increase your run time quite a bit.
toyw/me is offline   Reply With Quote
Old 12-31-2009, 12:44 AM   #7
changing battery as soons as possible so I can run my ax10 and recat with the same batteries.
Old 12-31-2009, 02:32 PM   #8
1) Change to the Tenergy 3800mah square battery - DO NO use a stick battery and there is no real need for splits. 2) Go to NitroRCX and pick up a ExceedRC charger 51C00-AC-Charger w/indicator light for all of $4 plus shipping. They work quickly and dependably.
PrivateerConcepts is offline   Reply With Quote
