01-16-2010, 01:52 AM | #1 |
Pebble Pounder Join Date: May 2007 Location: Little Rock
| Banebot 380 7.2v help
I just got my banebots in and Im having a heck of a time getting these motors mounted. What give. Im using the stock screws and I just cant seem to get the gears right. Either its too tight or not touching. I can get it to work right but as soon as I start to tighten down its back off track. Anyone have any tips for mounting these. Ive mounted the stock motors before and changed out a 540 on my scx10. These are just troublesome. Last edited by house_Fly; 01-16-2010 at 02:18 AM. |
01-16-2010, 10:44 AM | #2 |
Newbie Join Date: Jan 2010 Location: oregon
Make sure your screws go in nice and easy. I had to clean the threads out on the motor by running the screw in and out a few times with them out of the truck. After that they went in no problem. I used the stock pinion.
01-16-2010, 12:53 PM | #3 |
| I thought that might be it, so I took a look and the screws thread is different in the banebots than stock. So do I just keep screwing the stock motor mounting screws in the banebot?
01-16-2010, 03:25 PM | #4 |
The safe bet would be to take your motor to the hardware store and get the correct size. I didn't want to wait so I threaded the screw in and out a few times till it was smooth. I didn't see any damage to the threads on the screw.
01-16-2010, 06:53 PM | #5 |
Ok I have both motors mounted up. Finally. Now I just realised that if I press full throtle that the car dies and the fan turns off. This is in reverse of fowards. If I got slow and gradually pick up speed to full throatle it works fine. PLease someone help tonight I would like to to this thing to the local GTG tomorrow. Another problem is if it begins to crawl it kills it. Do I need to add capacitors? Last edited by house_Fly; 01-16-2010 at 06:59 PM. |
01-16-2010, 11:52 PM | #6 |
WOW I feel like an IDIOT. These motors are FFFFAAASSSST... But lots of low end where it needs it. I was using a near dead battery. Put in the 3600mah I had a dead 1500 (doh problem solved. haha |
01-17-2010, 11:36 AM | #7 |
Newbie Join Date: Jan 2010 Location: McArthur
wheres a good place to get the banebots? im getting real tired of the clod stall and have the 8t gears on order but my motors are starting to get really hot. do i need to replace the esc also or just the motors? thanks guys love this forum its been a lot of help and im really glad to see that we have our own section now!! |
01-17-2010, 03:46 PM | #8 | |
http://banebots.com/pc/MOTOR-BRUSH/M5-RS380-72 16.55 shipped for 2 motors. Look at the other thread on motors. to see how they perform | |
