02-25-2010, 02:54 PM | #1 |
Newbie Join Date: Feb 2010 Location: Boston
| ESC Wiring
I took the motors off to break them in and didn't keep track of which wires on the esc they connect to. Any one still have the stock setup or know the order. This is my current order Battery(Black/Negative), Motor(Yellow), Motor(Yellow),Motor(Blue),Motor(Blue),Battery(Red/Positive) I'm trying to figure out which motor wires go the rear and which ones go to the front. Thanks in Advance. |
02-25-2010, 04:02 PM | #2 |
Pebble Pounder Join Date: Jan 2010 Location: NEPA
Took then off to break them in??? they are electric not fuel, no need to break them in.. Here is factory wiring layout. rear motor yellow on top blue on bottom front motor blue on top yellow on bottom ESC layout with the rear end sitting on your left leg, all wires (esc & RX) facing you. left to right: black, yellow, yellow, blue, blue, red. HTH later Rich PS, do yourself a favor in the future. Follow the owners manual for break in. IE: most nitro/glow fuel, 3 tanks run rich with break in oil under no stress. electric, run right out of the box unless stated otherwise. |
02-25-2010, 04:45 PM | #3 |
lol...thanks for the wiring. from your left to right - is the first yellow (near the black) go to the rear motor or front. Same question for the blues? Everyone is doing all kinds of things to squeeze a little more perfomance out of their rs10 - I'd figured I try some too. I didn't see what harm it could do (aside from not knowing how to wire it back up, of course!) Check out this article - http://www.rcuniverse.com/forum/m_5628228/tm.htm Last edited by jcraw; 02-25-2010 at 04:48 PM. |
02-25-2010, 05:22 PM | #4 |
left to right 1st yellow rear 2nd yellow front 1st blue rear 2nd blue front. yellow yellow blue blue. later Rich |
02-25-2010, 05:51 PM | #5 |
Great. Thanks.
