03-22-2010, 10:04 AM | #1 |
Rock Stacker Join Date: Mar 2010 Location: Seattle
| Axial link swap ??
I got some bent links. Hunted down the right studs. But, the shock mounts just won't go over the round links. Can I force them on without breaking them, or is there a source for aftermarket ones? Do the Axial ones work? Again thanks. |
03-22-2010, 10:06 AM | #2 |
Rock Crawler Join Date: Aug 2009 Location: I'm a michigan boy can you feel that!
did you try putting the shock mounts on first and then the ends???
03-22-2010, 10:30 AM | #3 |
03-22-2010, 11:06 AM | #4 |
hmm id try using a little bit of grease to get them on, should slip right on then, just whip up the rest so your mounts dont slide.
03-22-2010, 11:47 AM | #5 |
Newbie Join Date: Jan 2010 Location: Antonito
i had to drill mine out a little & they worked just fine
03-22-2010, 11:52 AM | #6 |
Pebble Pounder Join Date: Feb 2010 Location: Spokane Valley
ya just take a drill bit and make it a bit bigger. also depending on what links you got you might be over the 12.5 comp limit like i am. good luck post pics if you are still having problems. Good luck Brent |
