08-06-2010, 01:33 PM | #1 |
Newbie Join Date: Jul 2010 Location: Sacramento
| slipping rear diff
im pulling it apart now to see whats up.. i pulled the inspection plate off the side and the motor is spinning still but no power to the wheels...
08-06-2010, 02:00 PM | #2 |
motor is done ...
08-06-2010, 07:28 PM | #3 |
well im new to electric rc stuff, my motor being done....not so much...went and got a cheap one to hold me out and its doin the same thing... spur gear? everything looks good to me...its kinda puttin power to the wheels but as soon as i put it down on the ground it slips right away...
08-06-2010, 08:21 PM | #4 |
so i have pulled it all apart and i cannot see where the problem is..what would cause the slipping?
08-06-2010, 08:42 PM | #5 |
Pebble Pounder Join Date: Apr 2010 Location: surrey bc
its most likely the pin in the spur gear housing mine went front and rear and just replaced them with a piece i cut off of a eyeglass screwdriver but allan keys work great too if u need a quick fix..Take the spur gear housing off and ur pin will probably fall out...You can also order ur hardened pins ZNO has them for around 5bks.
08-06-2010, 08:51 PM | #6 |
yeh i was searching and saw that...i am not 100% sure where to look for the pin, i have the bottom of the axle in my hand with it hooked up and i can feel no slip when i try to spin it and hold the other side. where is the pin exactly? in this spur gear? thanks Last edited by Foolsize; 08-06-2010 at 08:58 PM. |
08-06-2010, 08:58 PM | #7 |
just remove the 4 tiny screws around the housing and the pin is inside that.
08-06-2010, 09:14 PM | #8 |
there it is! hahaha...thanks!
08-06-2010, 09:56 PM | #9 |
Quarry Creeper Join Date: Jul 2010 Location: Independence
so what actually broke then?
08-06-2010, 10:09 PM | #10 |
ya was it indeed the pin?
08-06-2010, 10:09 PM | #11 |
Pebble Pounder Join Date: Jan 2010 Location: Vancouver
Just JB weld that thing together.Trust me.Ive changed multiples,and its a pain.The JB trick is holding nicely! |
08-06-2010, 10:43 PM | #12 |
Pebble Pounder Join Date: Jan 2010 Location: Emmett, ID
ZNO-RC sells hardened pins to replace the soft ones that come stock. Better to replace the perts with better parts IMHO.
08-07-2010, 12:07 AM | #13 |
i ended up using part of a hardened steel pop rivet |
08-07-2010, 01:10 AM | #14 |
Rock Stacker Join Date: Jun 2010 Location: Calgary
08-07-2010, 08:56 AM | #15 |
well i would have been scratching my head wondering what the heck....if it was not for rccrawler |
08-07-2010, 03:47 PM | #16 |
Pebble Pounder Join Date: Feb 2010 Location: Spokane Valley
you know i tried the hardend steel stuff and i broke those too lol. but i went to my lhs and i got some hinge pins for a losi mini t and those hold up damn good to my cobalts. well i hope that you get it figured out and not look like me when i put down my rig on the start line at a comp and broke both of the alan wrenches. it sucked being done before i even got started. Brent |
08-08-2010, 08:44 PM | #17 |
JB them!!! |
06-09-2011, 01:04 PM | #18 |
Quarry Creeper Join Date: Feb 2011 Location: Vancouver Wa, USA
Anyone done a write up (pics) on just what and how to "JB them" ? TIA Smitty |
06-09-2011, 01:11 PM | #19 |
Read some more and found it. Next time I will shut mouth and open eyes. |
06-09-2011, 03:44 PM | #20 |
Got it, TY ! Smitty |
