09-12-2010, 10:56 PM | #1 |
Newbie Join Date: Jul 2010 Location: RIP City.
| Does anyone else have this problem?
About two weeks ago my truck stops moving when i throttle it,but when i picked it up it the tires would spin when i throttled it,so i took it apart & found out that I snapped both front & rear spur gear rod pins. So I go ahead & make some new ones out of nails that were about the same thickness,I put them in & the truck was back in order.. tonight i go out & realize the front is doing what it did before,so i pull it apart & it was the same thing.. I guess what my question is does anyone else keep snapping those? |
09-13-2010, 12:54 AM | #2 |
Rock Stacker Join Date: Jun 2010 Location: oregon
i have only broke the rear, i replaced it with this. http://www.zno-rc.com/pages/products...drive_pin.html |
09-13-2010, 03:09 AM | #3 |
RCC Addict Join Date: May 2010 Location: So. Charleston. Wv
I never broke one of them, i Havnt broke anything on a redcat and i beat the guts out of it day in an day out. What type of setup do u have?? all stock? weighted?
09-13-2010, 03:35 AM | #4 |
I've got rovers,spacers in the shocks,rear steer lock out,& I made the truck sit a bit lower by moving the shock brackets down to 1/2 inch away from the rod ends.
09-13-2010, 07:09 AM | #5 |
RCC Addict Join Date: Jul 2009 Location: Blacksburg, VA
I'm almost wondering if there was a bad batch of those pins in some of the RS10's. I've never broken one of the pins (knock on wood) and I have a similar setup. Weighted wheels, rovers, etc... Either that or you guys are getting into some serious binds.
09-13-2010, 10:13 AM | #6 |
Pebble Pounder Join Date: Apr 2010 Location: Brighton, MI
Nails probably are not the best solution since they use cheap metal. If you can find a full size u joint you can use a needle bearing. My solution was to get a 3/32 hardened steel pin at Ace hardware ($0.20). Had to drill the shaft out to fit but it's only a few thousandths off so you're not removing much. Also, if you throttle it too much while its broke you'll eat up the cap that holds the pin. I plane to turn one out on the lathe out of aluminum this fall if time allows. If I get it done I'll post pics and let you know how it works.
09-13-2010, 11:19 AM | #7 |
Rock Crawler Join Date: Aug 2007 Location: Casper, WY
| I was wondering that too, we haven't broken anything in our trucks either.
09-13-2010, 04:46 PM | #8 |
I'll only used the nails cause I had no other ideas on what I could use that would be in the garage,I'll try the ace idea soon. Thanks for the help. |
09-13-2010, 04:53 PM | #9 |
Quarry Creeper Join Date: Jul 2010 Location: Independence
i never had the problem bought i bought the pins from zno. I couldnt get one of the gears aprt so i couldnt replace that pin. gonna have to buy the complete gear one day and replace the pin. i can tell you that the pin i did change was already bent and I barely ran it. I was able to get gear apart in a manor which didnt let me change the pin but that inn wasnt bent yet. I have also installed steel gears and 540's so it will bend. Its just a matter of time.
09-13-2010, 10:56 PM | #10 |
What was redcat thinking when they made steel gears but left the pin cover plastic? Thats like building a bunker out of concrete and rebar and then putting balsa wood for a roof.
09-14-2010, 10:24 PM | #11 | |
Rock Crawler Join Date: Jul 2009 Location: waterville
thats funny. i was wondering the same thing. the next time i tear apart my axles im going to make some spools to eliminate the plastic pin cover and pin altogether. when i did the 540's i replaced my pins( both bent from banebots 390's) i think its soft steel. i used allen wrench for the pins. most are hardened steel and cheap. i have put mine in some pretty hard binds with only dog bone failure. | |
