09-20-2010, 06:50 PM | #1 |
Rock Stacker Join Date: Jul 2010 Location: fredonia
| Verybig preoblem
i started my RS10 and when i give it some throttle it does not move. i have not changed any trim settings and i looked in the gearbox and it looked like nothing was wrong. also there is no weight in the wheels so its no pushing that much weight. PLEASE HELP
09-20-2010, 06:56 PM | #2 |
RCC Addict Join Date: Jul 2009 Location: Blacksburg, VA
Do the wheels move if you hold the rig off the ground and throttle it? If nothing at all happens in forward or reverse you might wanna check your connections. Especially the ones from the ESC to the motors or to the receiver...something might've came loose.
09-20-2010, 07:06 PM | #3 |
the motor work fine and everything it is just when it is on the ground and u give it some throttle it is just like the gears spin inside the gearbox but i opened up the gearbox and there is absolutely nothing wrong.
09-20-2010, 07:44 PM | #4 |
RCC Addict Join Date: May 2010 Location: So. Charleston. Wv
umm recheck all the connections and check the gear to see if its tight kinda sounds like something is loose.. is the battery charged up good?
09-21-2010, 03:40 AM | #5 |
Rock Stacker Join Date: Jun 2010 Location: oregon
sounds like the spur gear pins are sheared
09-21-2010, 06:10 AM | #6 |
i took apart the entire gearbox and there is nothing wrong with the pins. everything is fine until i put the tire on and it sounds like the gears ar spinning without moving the axle. If the gears would be striped wouldnt there be pieces of plastic in the gearbox
09-21-2010, 09:12 AM | #7 | |
Quarry Creeper Join Date: Apr 2010 Location: Idaho
What the guys on there are talking about with the spur gear pin is on the final drive gear (spur gear) there is a plate that bolts to the side of it with 4 small screws. Behind this plate there is a pin that goes through the shaft and essentially is the only thing connecting the gear to the tires. The factory pins have been known to be extremely weak and can sometimes sheer very easily. So it would do what you are describing by having the gears drive inside the case but no movement at the tires. Here is a link to some new hardened pins http://www.zno-rc.com/pages/products...drive_pin.html | |
09-21-2010, 09:54 AM | #8 |
Thanks for the help you guys i will definately get some of those. just one more question do i need 2 sets of those pins for both axles or just one set because both axles are shot
09-21-2010, 11:17 AM | #9 |
Pebble Pounder Join Date: Apr 2010 Location: surrey bc
Thats pretty weird for both pins to shear at the exact same time hmmmmm well if it is the pins which sounds like it is hit up ZNO-RC for some new ones there GREAT people to deal with and thell take good care of you!
09-21-2010, 12:24 PM | #10 |
you only need to order 1, it has 2 pins 1 per axle.
09-21-2010, 08:15 PM | #11 |
Pebble Pounder Join Date: Apr 2010 Location: Brighton, MI
Or just get some 3/32 hardened steel pins from ace hardware and drill out the hole. Its only a couple thousandths of an inch bigger but they shouldn't snap, they're in town today, and they're only $0.18 each.
09-22-2010, 08:03 PM | #12 |
well i got to the pin. i could call it 3 pins if i want to. so i ordered the ones from zno-rc. but i think i might do the 3/32 pins if they break again thanks again for all the help
09-23-2010, 03:29 PM | #13 |
Your order has shipped . Let us know if you do break this pin though. We have put ours through quite a bit of abuse and have sold probably 50 sets of these pins since we started selling them this summer but we have not had any feedback on how they are holding up for everyone else. If anyone has these and has broken a set I would love to know about it. Thanks |
09-23-2010, 04:00 PM | #14 |
I will keep u guys informed on how they are doing once i put the new ones in from u guys
