09-29-2010, 06:19 PM | #1 |
Rock Crawler Join Date: Aug 2010 Location: Salt Lake
| Good weight starting point
I'm about to upgrade the stock tires on my rs10 to some hb rovers, what is a good starting point as far as weight for the axles? front and back.
09-29-2010, 07:21 PM | #2 |
Newbie Join Date: Jul 2010 Location: Parker, Co.
X2 Got some rovers coming in the mail.
09-29-2010, 07:28 PM | #3 |
Quarry Creeper Join Date: Jul 2010 Location: Independence
im not running any yet. seems the norm is about 3 oz or so in each wheel (6 oz total) and about 4 in the back
09-29-2010, 08:11 PM | #4 |
I have access to sticky weights from work, so I have plenty to mess around with.
09-30-2010, 03:47 AM | #5 |
Rock Stacker Join Date: Jun 2010 Location: oregon
i started with 7 oz each in front and 2.5 each in rear, but have since taken it all out of the rear and left the front.
09-30-2010, 06:49 AM | #6 |
RCC Addict Join Date: Jul 2009 Location: Blacksburg, VA
Good starting point...pop an ounce in the fronts and none in the back. If that seems too light, add a little more. Some of it depends on your servo too. If you put weight in and the servo has problems turning the rig, take some out. Personally, I run a couple of ounces in each front and none in the back.
09-30-2010, 02:40 PM | #7 |
Rock Crawler Join Date: Aug 2007 Location: Casper, WY
I'm running 4oz fr and 0 rear.
09-30-2010, 03:12 PM | #8 |
I have hitec 645 front and back.
09-30-2010, 03:21 PM | #9 |
Rock Crawler Join Date: Jul 2009 Location: waterville
4.5 oz front 0 oz rear. i recently put new sneakers on my rs10, so i think i will be adding another oz. per tire front and rear to help gain traction. just start in the front with a little at a time. keep going until your happy or start to see a drop in performance.
10-02-2010, 10:00 PM | #10 |
Pebble Pounder Join Date: Apr 2010 Location: Brighton, MI
I'm running 6~7 oz per wheel in front and none in rear. I have a 403 oz-in servo that seems to handle the weight. I like this setup with DIG since I can drag the rear up a steep ledge without fliping
10-31-2010, 05:13 PM | #11 |
Newbie Join Date: Oct 2010 Location: chocowinity
i'm running 6oz a piece upfront and 3oz in the back. with stock servos. so far so good. also moved to the inner hole on the steering horn for a lil more torque, granted i cannot turn as tight but hey we have rear steering. |
