11-28-2010, 02:02 PM | #1 |
Pebble Pounder Join Date: Oct 2010 Location: Castro Valley
| Stock Redcat motors never get hot
When I got my Redcat used the motors would run so freakin Hot. I found out that the aluminum hex nut that the rim sits on was being smashed by the rim lock nut. I think this happened from the rims being over tightened. I have since put in new stock motors from Redcat , m2 dig , dx3e, and 5000 sub c, steel gears and 8t pinion. I can run this thing well over an hour with my buddy's XR10 and my motors barley get warm. I would have never thought to check the hex nut until I installed steel gears. If this nut is snug like this from the factory I can see why people burn up so many stock cans.
11-28-2010, 08:58 PM | #2 |
Rock Stacker Join Date: Dec 2009 Location: windsor
same thing happened to me. got a piece of string wrapped around thde hex. and tightened uo the axle pretty good....fried the motor with in a couple runs...so i just switched over to banebots. good upgrade, still clod stall but way better than stock motors.. |
11-29-2010, 08:20 PM | #3 |
Rock Stacker Join Date: Oct 2010 Location: Malaysia
may i know how u fixed this issue? im thinking of loosening the wheel nuts abit but scared to loose the wheel itself |
11-29-2010, 10:18 PM | #4 |
Rock Stacker Join Date: Nov 2010 Location: Rocky Ford
Take the wheel off and there is a little aluminum hex with an set screw in it... loosen the set screw and give it a bit of play so that it's not in a bind and then tighten the setscrew back up. Put the wheel and tire back on and problem solved. |
11-29-2010, 10:35 PM | #5 |
yep!
11-29-2010, 10:54 PM | #6 |
| thanks for sharing and i just checked my hex screw is very loose that it came out after i pulled the tires off :( guess i have to check all of them later.
11-29-2010, 11:22 PM | #7 |
you can feel the play by turning tire left to right. It should only be loose enough to feel play in axle shaft (dog bones) .
