12-23-2010, 07:39 PM | #1 |
Rock Stacker Join Date: Jul 2010 Location: fredonia
| servo question
so i want to run a different servo for a plow i made. i know a rs10 isnt a scaler but its all i got. so if i get another servo or steal the one from the rear can i make it work separately from the steering to make the plow move?
12-23-2010, 07:40 PM | #2 |
i also use the stock controler with stock servos
12-23-2010, 07:49 PM | #3 |
RCC Addict Join Date: May 2010 Location: So. Charleston. Wv
One of two things u can do. lock the rear steer out and use that channel or get a different radio with 4 channel as for the plow. go look at peoples builds on the plow and go from there |
12-23-2010, 07:49 PM | #4 |
RCC Addict Join Date: Apr 2006 Location: Home of the ORIGINAL Terminator chassis
You wouldn't really be able to use the stock controller as the servos are tied together with it's pre-set internal programming.
12-23-2010, 09:25 PM | #5 |
so whats a cheaper controler that would work with this and the rs10?
12-23-2010, 10:02 PM | #6 |
If your wanting to upgrade just for the plow purposes spend the extra time an read the threads and get a good radio
12-24-2010, 07:57 AM | #7 |
If all you want is 2WS and a plow, you could take a Traxxas TQ3 and control the plow with the 3rd channel. If you want to keep 4WS and add the plow, you'll need a 4+ channel radio. |
12-25-2010, 10:16 AM | #8 |
RCC Addict Join Date: Jul 2009 Location: Blacksburg, VA
Also, keep in mind that if you go for a tq3 radio, you'll need to mod the radio to a 3 position 3rd channel setup to be able to raise and lower the plow if you make a setup like that.
