01-06-2011, 11:54 PM | #1 |
Rock Crawler Join Date: Dec 2010 Location: Beaumont Tx!
| Help with shock rubbage????
Anyways I bent my rear links at about a 35* 7/8" from where the bottom joint meets the link and I couldn't get the shocks to sit where they would not scrape the hell out of the motor since I lowered it. I know some guys are running bent links with the shocks moved back, so what am I doing wrong?????? Hell the link itself will hit the motor if it doesn't stay perfectly straight so WTF?
01-07-2011, 01:20 AM | #2 |
Rock Stacker Join Date: Oct 2010 Location: Malaysia
i had the same issue using bent links, i just clocked the axle, gave it a bit of negative caster.
01-07-2011, 06:37 AM | #3 |
Newbie Join Date: Nov 2010 Location: Texas
I also had this problem when installing bent links. I use a nut on both ends of each top link to help rotate the axel.
01-07-2011, 11:23 AM | #4 |
Pebble Pounder Join Date: Sep 2010 Location: Brussels/Belgium
Kc, could you put a picture of your mod it seem simple but I do not understand exactly where to put the nuts... |
01-07-2011, 01:48 PM | #5 |
No problem here you go. I placed a 3mm nut and washer at each end. I also moved the lower links in the center holes on the frame/battery tray to help rotate the axel were the motor would clear. Hope this helps Last edited by Kcsport; 01-07-2011 at 01:54 PM. |
01-07-2011, 02:12 PM | #6 |
Now I will have to watch for the steering rods not to rubb the obstacles...Or create a skuid plate, but the shape of the axxle make it difficult to design...
01-07-2011, 04:38 PM | #7 |
Pebble Pounder Join Date: Oct 2010 Location: Castro Valley
01-07-2011, 06:23 PM | #8 |
RCC Addict Join Date: Jul 2009 Location: Blacksburg, VA
I'll second that delrin links recommendation. I have 5/16'' delrin uppers, lowers, and steering links and haven't had a problem with them.
01-07-2011, 09:10 PM | #9 |
| after clocking the axle the steering drag links will be something to look after. i did the BTA mod shared by CPE it really is easy and uses all stock parts.
01-07-2011, 11:41 PM | #10 | |
01-08-2011, 08:10 AM | #11 |
Good tires go a long way...so does a proper setup. If you don't have a low center of gravity on your rig and your electronics aren't as low as possible, you'll have a pretty tough time with obstacles like that, no matter how bent your links are. Spend some time reading through some of the build threads in the berg and bully sections for some ideas and inspiration in how to setup your rig. They might be completely different rigs, but things like shock tuning, electronics placement, etc... help out a lot.
01-08-2011, 09:10 AM | #12 |
Rock Crawler Join Date: Feb 2010 Location: Sturgis
put your link on the outer mounting tab on your axle, that will get you 1/4 inch further from your motor . You just need a longer screw.
01-08-2011, 02:32 PM | #13 |
Newbie Join Date: Dec 2010 Location: Flour Bluff
Also in that vid they had a dig, you would not be able to climb something like that without one because your rear wheels would just try to drive under you and flip you over.
01-08-2011, 04:28 PM | #14 |
