02-20-2011, 01:30 AM | #1 |
Pebble Pounder Join Date: Nov 2010 Location: Spain
| Pinion 38-48 pich?
Hello. I have 540īs motors in my RS10 and I would like to change the pinions but I donīt know what to buy because there are two sizes 38 pitch and 48 pitch!! What is the correct size for the RS10īs transmision? Thanks!!! |
02-20-2011, 01:17 PM | #2 |
Newbie Join Date: Oct 2010 Location: Memphis
i believe there 48 pitch
02-20-2011, 02:25 PM | #3 |
RCC Addict Join Date: Apr 2006 Location: Home of the ORIGINAL Terminator chassis
48 metric pitch.
02-20-2011, 03:17 PM | #4 |
Newbie Join Date: Jul 2010 Location: durango
ive been using berg pinions for about a month now with no problems. i also have 540s and i still have the plastic gears.
02-27-2011, 08:40 AM | #5 |
Newbie Join Date: Dec 2010 Location: dracut
If you have a digital caliper you can calculate the pitch. You can also buy pitch gauges. To calculate pitch you take the # of teeth and divide it by the pitch diameter. The pitch diameter is measured from the center of each tooth. Easiest way is to take the # of teeth add 2, then divide that by the OD of the gear. Metric measurements are designated by Modules, or Mod.... 1 MOD = 25.4P, 2 MOD = 12.7P. So if there is a P designation then its unified (standard), not metric. The only time it doesnt "really" matter if its metric or standard is when you interchange between 32P or 0.8 MOD, for they are close enough for our applications.
02-27-2011, 08:01 PM | #6 |
Newbie Join Date: Feb 2011 Location: Quilcene
looks like 48p to me
02-28-2011, 06:29 AM | #7 | |
Pebble Pounder Join Date: Jan 2011 Location: Deltona Fl.
very cool! good info! | |
02-28-2011, 07:52 AM | #8 |
Iīve just bought a pitch guaget !! It only cost $4!! Thanks |
