05-15-2011, 10:34 AM | #1 |
Newbie Join Date: Mar 2011 Location: Pittsburgh
| rs10 rear axle issue
alright guys, my rear motor is working fine, the gears all spin propertly, when I lift my truck up, the rear tires spin, when I put weight on it, the tires wont spin, but the gears are still spinning. Something is wrong with the gear on my axle, not sure how to to fix this. any ideas? |
05-15-2011, 11:00 AM | #2 |
Newbie Join Date: Mar 2011 Location: Mesa
Sounds like the metal pin in the spur gear broke. Thus just happened to me it's a real easy fix, there are a lot posts explaining the signs and how and what you can use to repair it!
05-15-2011, 11:04 AM | #3 |
Quarry Creeper Join Date: Mar 2011 Location: Houston
Sounds like a common problem. Shear pin. Your motor spins your gears which transfer to your axle which will spin your axle shafts. BUT, most likely your shear pin is in 3 pieces. Tear that axle down until you get to the gear that has dogbone connectors on each side. Take off the 4 small screws and you'll find your shear pin; prob. broken. Several ways to replace with something stronger.
05-15-2011, 01:18 PM | #4 |
That was it. Thanks for the help, I would have never found that. I guess these new 540's I am running put a lot of power to the axel |
05-15-2011, 01:31 PM | #5 | |
Rock Crawler Join Date: Feb 2011 Location: Courtenay
540's? That stock diff pin didn't have a snowballs chance in hell. Hope your running metals gears now too. if not, order em now so you have less down time when they go. | |
05-16-2011, 07:22 AM | #6 |
Pebble Pounder Join Date: Apr 2010 Location: Canada
| Been running 540's over a year on the stock pins and gears,just a little jb weld around the pin.....I dont baby it I debead tires regularlly
