06-25-2011, 01:15 AM | #1 |
Newbie Join Date: May 2010 Location: brisbane
| big thumbs up for crawling
Just got my redcat rs10 xt 2 days ago and i am loving it!!!! im hooked, took it for a 2hr drive today and only reason i left was cause the misses wanted to go (going to have to build her a mrc or something ) i ended up getting with the cat , set of rover white dots, 2 mayhem servos and a cc bec and will be putting the servos on soon cause the front one has started clicking i have one other problem as well, the right hand front wheel when driving wobbles around as if it is buckled has anyone had that?? or is there a something playing up? it makes it pull to the right as well....... anyways ill take some photos as i start changing things and post them up |
06-25-2011, 01:44 AM | #2 |
Newbie Join Date: Jun 2011 Location: Marion
Congrats on getting the crawler but tough luck on the servo and wheel. Should be getting mine in a couple of weeks. Finally nice to be able to run longer than 15-20 mins on one battery. I'm hoping I can get hooked also. Tired of going fast, that just breaks things more easily.
06-25-2011, 06:20 AM | #3 | |
RCC Addict Join Date: Jul 2009 Location: Blacksburg, VA
06-25-2011, 02:50 PM | #4 | |
thanks mate ill you posted on how it goes | |
06-25-2011, 02:53 PM | #5 | |
I've started to look at a baja 5b so hopefully if i get one i dont break to many things.... | |
06-25-2011, 03:57 PM | #6 |
Quarry Creeper Join Date: Mar 2011 Location: Houston
If you've checked everything that owens mentioned, check your dogbone. It may have bent right at the end if you tried to power out of a bad bind. Although, I'm not convinced that a stock motor has enough power to achieve this. I did have this happen to me with 540 motors-I believe due to a little slop 'n slack in the axles. My symptoms were the same as yours-wobbling wheel.
06-25-2011, 10:33 PM | #7 |
Pebble Pounder Join Date: Jan 2011 Location: london
this may also sound silly but just a theory, white dot rovers are pretty thin rubber (mine are anyway) i have seen a little warp wobble out of mine when i first put them on because the foam got kinda wadded up more in one area than the others, if all of jsowens recomendations dont work, give this a check and try massageing the tired all around to try and even out the foam... just a thought... the one good thing is, unlike nitros where a lil wheel woble and high speed equals disaster, crawlers dont go fast enough for a LITTLE wobble to be a big problem...i narrowed my stock wheels just to see if i could, gave one wobble and have never had it matter.... |
06-26-2011, 03:38 AM | #8 |
pulled the wheels off today and had a quick look and everything seemed fine i'll pull the knuckle of and have a bit more of a look tomorrow. i also put the cc bec, mayhem servo and flipped the electronics tray over to lower it (probably pointless but the more weight low counts ) i went to put the rear servo in and found that one of the wires has been cut when i got it out of the pack and to rub salt in the wound after i took it for a drive this morning i noticed the bottom cap on the shock had unscrewed and i lost all my shock oil does anyone know what weight the stock shock oil is? i couldnt find anything in the manual..or since im buying some should i change all of the shocks to a complete different oil? started putting my rovers on as well and gave up on the second side of the rim...hopefully someone has a thread with some tricks for beads |
06-26-2011, 09:33 AM | #9 |
well if i was to guess i would say 30 weight oil because it is the most common stock weight that shocks use.. if you buy a bottle of oil you have more than enough to fill all the shocks with the same oil so you can be sure.
06-26-2011, 10:44 AM | #10 |
Go ahead and get yourself a bottle or two of shock oil. That way you can try out some different weights to your preference. Maybe like 30-35 and something heavier for experiment. And if you decide on getting just one bottle, you can expect it to last a very long time-so it's worth the 3-5 bucks you might pay for it in your lhs.
