12-07-2011, 02:11 PM | #1 |
Rock Crawler Join Date: Nov 2011 Location: Wister, OK.
| Bad motor
Is there a place that sells the stock motors? The front one in my BRAND new RS10Xt is not any good, freezes up and won't turn...and yes, it is the motor, I am holding it in my hand as I type, well, it's laying in front of me! Do I have to buy a whole set? I need to order them right now so I can have it ready by Christams, HELP!! I need a link, a source, somethigng for a stock motor or two aftermarket ones. Thanks. |
12-07-2011, 02:58 PM | #2 |
try red cat racing, all the parts and part numbers are in the manual. theres even a phone# and website. you have looked at the manual , right?
12-07-2011, 03:17 PM | #3 |
Newbie Join Date: Oct 2011 Location: St. Robert
If you just bought your redcat, go to their website and fill out the warranty form, they will more than likely send you a new one free of charge...thats what I did.
12-07-2011, 03:23 PM | #4 |
Fan of wheelspeed Join Date: Jun 2011 Location: Southern IN
| Yup, Redcat is awesome on warranty claims. I had my servos strip and they sent me twp new kits. Just tell em and I'd almost be willing to bet you'll have a email within a day saying one is on its way |
12-07-2011, 04:30 PM | #5 |
RCC Addict Join Date: Aug 2011 Location: round pond (aka clarksville TN)
look inside the vent holes on the bad motor, i'll bet the white plastic cooling fan came loose, i had one do the same thing take the butt end of the motor off, take the fan out,and throw it away then put the motor back together....it'll work fine, been running mine like that almost since i got it bout 6 months ago! you will see the fan movin when you try to turn it if it is loose |
12-07-2011, 05:20 PM | #6 |
Rock Stacker Join Date: Sep 2011 Location: Oceanside
Ditto on the cooling fan. Except I epoxied mine back in place.
12-07-2011, 05:26 PM | #7 |
12-07-2011, 06:44 PM | #8 |
Doesn't look like the fan. I went to the web sight and just ordered another motor so hopefully I will be good to go! I also noticed to go in reverse, I have to push the trigger forward, let it come back, then push it forward again for it to back up, is this normal? |
12-07-2011, 07:36 PM | #9 | |
Rock Crawler Join Date: Feb 2011 Location: Courtenay
As for motors. My fans melted inside the can, just smeered around the spindle. so when they caused problems, they came out through the vent holes in chunks. problem solved. also, make sure the wires are still connected to the motors. as stock, the tires rub and tear the wires off. Last edited by The Jackalope; 12-07-2011 at 07:41 PM. | |
12-07-2011, 07:57 PM | #10 | |
12-08-2011, 01:40 PM | #11 |
12-08-2011, 06:04 PM | #12 |
My fan was alright until a buddy with a out of control Baja 5T tail whipped my RS10 30' thru the air. Possible your ESC is starting to die also. My stock one lasted only a few batteries. (2s) |
12-08-2011, 06:07 PM | #13 |
| mine did also bout 3 months after i got it worked fine when i put it up, the next time i messed with it, it would work in forward fine, but moved real slow and no drag in reverse
12-16-2011, 06:54 PM | #14 |
| Re: Bad motor
Got the new motor in and it looks like I (my daughter) is good to go for Christmas morning! |
