02-28-2012, 05:45 PM | #1 |
Newbie Join Date: May 2011 Location: orangevale
| quick question just put some new banebot 395 on my rs10 and now the rear motorwont turn the tires on any kind of incline or bind. i bought 4 of these motors and tried them all and does the same shit. the front works fine. is the stock esc goin bad? also have all metal gears, aluminum pin plate and hardened pins so i know nothins broke. thanks for the help. |
02-28-2012, 05:58 PM | #2 |
RCC Addict Join Date: Aug 2011 Location: round pond (aka clarksville TN)
| Re: quick question
have you tried switchin the wires-like hookin the rear motor up to the front motor wires? that would let you know if it's the esc!
02-28-2012, 06:00 PM | #3 |
Fan of wheelspeed Join Date: Jun 2011 Location: Southern IN
| Re: quick question
Does the motor run at all or is it just that the tires wont move?
02-28-2012, 06:38 PM | #4 |
Rock Crawler Join Date: Feb 2011 Location: Courtenay
| Re: quick question
check that your pinion on your banebots is nice and snug. I just had that problem the other day. Open the little 3-screw window on the diff, hold a wheel, and slowly give it gas.
02-28-2012, 06:49 PM | #5 |
| Re: quick question
all the motors worked on the front axle just the rear is actin like my 10 year old! it will work until an incline and then stops turnin. i also filed a flat edge on my motor so the pinion wont break loose.
02-28-2012, 06:54 PM | #6 |
RCC Addict Join Date: Jan 2011 Location: Bozangeles
| Re: quick question
That is known as clod stall.
02-28-2012, 07:04 PM | #7 |
| Re: quick question this is the most extreme form of clod stall i have ever seen then. it wont work on some rocks that it could easily climb before. |
02-28-2012, 07:19 PM | #8 |
Rock Stacker Join Date: Jul 2010 Location: Santa Cruz
| Re: quick question
what kind of battery are you running? try a fully charged batteries in the rs and your controller. low voltage has giving me some weird issues. Also, did you try using your steering channel as your throttle?
02-28-2012, 07:29 PM | #9 |
| Re: quick question
7.2 5000 venom. this is prob a newbie question but how would i use the steering channel as throttle? do i change on the remote? BTW santa cruz is a cool spot. we always take our fireworks to the beach there for the 4th
02-28-2012, 07:48 PM | #10 |
Rock Crawler Join Date: Aug 2011 Location: south shore Ma
| Re: quick question
Just swap the plugs on the reciever. What if you go up the rock in reverse does the front do it then
02-28-2012, 10:32 PM | #11 |
Newbie Join Date: May 2011 Location: Hollister
| Re: quick question
Keep the updates coming I was thinking about ordering a set of these. Thanks!
02-28-2012, 10:49 PM | #12 |
Quarry Creeper Join Date: Mar 2011 Location: Houston
| Re: quick question
Do the Banebot 395s have a rounded shaft like the 390s? If so, did you grind a flat side on the shaft for the grub screw of the pinion to rest on? That's a must to ensure your pinion isn't slipping.
02-29-2012, 08:09 AM | #13 |
| Re: quick question
yes a rounded shaft and i filed a flat edge so the grub screw wont slip . thats why im thinkn its the stock esc but if the front is good could it still be the esc? the 395s seem to run nice on front axle so im out of ideas for what the problem could be.
02-29-2012, 08:12 AM | #14 |
| Re: quick question
check that pin. I've went through two sets, one set was hardened. I ended up using a hardened drill bit.
02-29-2012, 08:42 AM | #15 |
| Re: quick question
yea i switched out my hardened pins for a cut allen wrench in an aluminum plate so i have no problems there. this is really startin to piss me off.
02-29-2012, 08:47 AM | #16 |
| Re: quick question
is it possible the esc is giving enough power to the front but not the rear? throttle control is set the same on my tx but im not really sure if this is possible.
02-29-2012, 09:33 AM | #17 |
Pebble Pounder Join Date: Nov 2011 Location: Fresno
| Re: quick question
Swap motor wires from front to back. I know someone mentioned that already, but I didn't see the answer. If the rear then goes as well as the front was, its the esc. Esc can go bad in just one direction, I just troubleshot my buddy's Losi this weekend, same issues.
02-29-2012, 09:35 AM | #18 | |
| Re: quick question Quote:
02-29-2012, 09:47 AM | #19 |
| Re: quick question
sorry forgot to reply to that post. i hooked up the rear motor to the front wires that connect to the esc and the motor worked fine. these bane bots were brand newso its got to be the esc then eh? thanks
02-29-2012, 10:51 AM | #20 |
| Re: quick question
how many turns are the banebots? I wonder if they just don't have the torque to move the thing? I would try what Jcplante suggested. Turn the truck around and drive backwards up the incline. See if the front axle now has the problem.
quick question - Similar Threads | ||||
California Gun owners. Quick question, need a quick answer. | Szczerba | Chit Chat | 8 | 11-23-2010 12:35 AM |
a quick question? | Robb8 | Electronics | 2 | 01-17-2010 07:08 PM |
Quick question | djjiz | Minnesota | 13 | 09-04-2009 08:58 PM |
quick question | grapegoat | Tools, and Procedures | 2 | 08-17-2007 05:42 PM |
Quick Question... asking for quick answer.. | JeeperoManiako | Electronics | 0 | 10-13-2006 06:47 PM |
