03-25-2012, 10:57 PM | #1 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
| lipo question
I am going to ask here first and it no one knows, i will go ask in the correct sub forum. I was doing some reading on lipos and read the you can get packs with 2sets of seriesth cells wired in parallel to in increase capacity. So it would be say a 2s2p pack. does that mean if i bought a set of 2s packs, that i could wire a parallel adapter to them? I was curious about this before and now i am even more so. i dont seewhy not, so long as the packs are identical and properly balanced. Thoughts? |
03-26-2012, 06:18 AM | #2 |
Pebble Pounder Join Date: Nov 2011 Location: Rhode Island
| Re: lipo question
Yes, can be done. Lithium Polymer (Lipo) Battery Guide - ProtoTalk.net Personally, for a crawler I'd buy the manufactured pack with the specs I needed rather than link muli cell packs with a harness. But then again, what did you have in mind? Also, checkout 18650 Lithium cells. Much easier to assemble packs and still 3.4Vs per cell. You can get them with voltage protection built in to each cell so things don't go BOOM. Have been meaning to try a two and three cell 2400mah 18650 pack in the Rockslide. It's on the ever growing "list." |
03-26-2012, 08:08 AM | #3 |
| Re: lipo question
well i am looking at buying two of the zippy 2200mah packs and running the harness. they are ebay, 2 packs and the harness for like 40 bucks. i think this will get me the weight distribution i want and still give me good run time. not looking for a ton of performance, just capacity. i might move up to the banebots down the road, but for now i like my setup. do wish there was an option between 2s and 3s, 11 volts is kinda pushing it on the stock ECS lol. i could up grade the ECS later, but for now that is very low on my "list". i was going to stick with Nimh, but i think i over discharged and then in turn over charged one of my 800 Mah packs, by the time i buy some 5000 Mah packs and extra charges, i can buy these lipos and half a charger. maybe i can get this all for Father's day ;)
03-26-2012, 05:27 PM | #4 |
Pebble Pounder Join Date: Dec 2008 Location: Side of a MOUNTAIN
| Re: lipo question
There's nothing at all wrong with using multiple packs to get the "size" you want. I've been doing it with airplanes for years. It's much more versatile that way- you can parallel as many packs as you want. Buying packs with parallel cells IMHO is a bad idea- you get a better matching charge with separate packs.
lipo question - Similar Threads | ||||
Lipo question | adamargue | Electronics | 6 | 10-29-2010 03:05 PM |
??lipo question?? | 73formulabird | Electronics | 7 | 03-15-2010 09:04 PM |
mm and lipo question | SUPERCLODBUS | Electronics | 5 | 02-06-2009 09:37 PM |
7.4v LIPO and 11.1v Lipo and charger question and help. | 4x4Crawler4LIFE | Electronics | 5 | 02-27-2008 09:15 PM |
lipo question | cossack | Electronics | 1 | 03-03-2007 12:42 PM |
