08-07-2013, 04:32 PM | #1 |
Rock Crawler Join Date: May 2013 Location: plains
| any thoughts
Ok so out testing my rs10 I found climbing my rear tires don't spin as well as the fronts. For example when I go up a rock ledge my front tires that are off the ground are spinning as my rears aren't goin anywhere. Any ideas what this could be? They seem to run fine when rig is flipped over checking to see if the rears cutting out. Quick run down on what I'm running. Stock red cat motors with a single sidewinder ESC wired to run both motors. |
08-07-2013, 06:08 PM | #2 |
RCC Addict Join Date: Aug 2011 Location: round pond (aka clarksville TN)
| Re: any thoughts
it's called clod stall......use the search tool in this thread. everything you have and will experience with a RS10 has been covered in here before. just my $0.02 |
08-07-2013, 07:45 PM | #3 |
| Re: any thoughts
Cool thanks.
08-25-2013, 08:15 AM | #4 |
| Re: any thoughts
check the drive pin in the axle
any thoughts - Similar Threads | ||||
thoughts | griz | Axial Wraith | 20 | 03-21-2012 12:30 PM |
Your Thoughts | LostCrawler | Axial SCX-10 | 6 | 02-01-2011 12:19 PM |
um...... your thoughts | 3speed | Chit Chat | 38 | 01-31-2009 08:43 PM |
