Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Redcat Crawlers
Thread: Scx10 axles on Everest
Old 07-09-2017, 08:21 PM   #1
Default Scx10 axles on Everest
I'm sure its out there somewhere but all I can find is people changing the lockers not the axles. Can you bolt up a scx10 axle under the Everest? Sorry if this is a dumb question or if it's already been asked.
TIREBUSTER is offline   Reply With Quote
Old 07-10-2017, 01:56 AM   #2
Default Re: Scx10 axles on Everest
That's because the stock plastic diff lockers are terrible and they will go wrong. I own a Maverick Scout (pretty much the same sans the 4ws). At first I had installed the "ugraded aluminum diff of fleabay and it was ok. At a later time I was given as a gift a set of used scx10 axles, quality was better but I had to make fit the 4link (stock axial is 3link) uppers and match the driveshafts since the axial pinion uses a through hole. I have ditched the scx10 axles now and replaced them with AR60s. I truly love em.. the rig is much better and since we don't have comps here in Greece (..yet?) the extra width is of no concern.
Vagos2 is offline   Reply With Quote
Old 07-10-2017, 10:53 AM   #3
Did you have to modify the ar60s at all?
Old 07-10-2017, 08:32 PM   #4
AR60 axels will require different suspension links to eliminate binding. At least that was my experience adding them to my E10. Boom Racing Aluminum links for the Axial Wraith worked perfectly for me. Huge difference with the AR60's though and like Vagos said, the extra width is amazing.
I would highly recommend picking up an axial transmission if going with either the AR44 or AR60 axles.
robowarrior23 is offline   Reply With Quote
Old 07-10-2017, 11:00 PM   #5
Not at all, I am using bent Rc4wd rod ends that are longer than stock and got lucky with pinion angles, they are good! I think we got you hooked on the AR60 idea..
Some minor downfalls are:
1. I had to use some spacers to prevent binding of the shocks.
2. Stock tranny has D shaped outputs and the scx10/ar60 have a through hole. The axial plastic driveshafts are the same sans the through hole though. So (and being a cheepassmonkey...) I used stock halves (1 male-1 female) on the gearbox and axial on the axles. It took only one of each heheheh. A temporary solution of course..
I am at work now (and on the other side of earth...) but should you want to I can take some pictures to show how the AR60s fit for now..
Old 07-11-2017, 07:10 AM   #6
Hope they are clear enough..
Old 07-12-2017, 07:52 AM   #7
I think I am hooked on the ar60 idea haha Thanks for all the input so far!! Only couple more questions. Does it matter what axial tranny I get and is there a lightly upgraded one for not much more than stock? What did you use for spacers on the shocks? And last question, did the swap require you to make that white piece on the axle or is that just one of those pieces for keeping the axle from trying to move?
Old 07-12-2017, 03:10 PM   #8
The white tower you see is a upper link riser I fabricated myself. It is not, by any means, essential to the swap. I still have the stock tranny and just used 1 axial driveshaft to fit axles. If you change to an scx10 gearbox box you ought to change the skid also or drill two new holes... Shock spacers are simply piecies of aluminium tube..
Old 07-12-2017, 06:12 PM   #9
Alright awesome! I appreciate all the help and the pictures! Looks like it's time to start ordering some parts!
Scx10 axles on Everest - Similar Threads
axial parts in my everest axles hillbillyrc Redcat Crawlers 26 07-30-2018 12:49 AM
maxstone or everest to scx10 conversion dubyas1989 General Crawlers 56 03-28-2016 09:41 AM
how to make strong RS10 axles? or everest 10? dirtman71 Redcat Crawlers 12 07-22-2015 09:01 PM
Everest 10 axles worth upgrading? bryner250 General Crawlers 0 06-27-2015 06:54 AM
