Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Redcat Crawlers
Thread: Tapered the body
Old 02-04-2017, 07:41 PM   #1
Default Tapered the body
Bored with the way it looked, and needed more clearance for the 5.5" cut Trepadors, so I went to cutting away. Don't mind the two holes. They are from mock up on another truck I'm building.
rsb5772 is offline   Reply With Quote
Old 02-04-2017, 09:39 PM   #2
Default Re: Tapered the body
Which tire?
Old 02-10-2017, 10:30 PM   #3
These probably. I do like the realistic one too, name of them escapes me, but they look nice. I could go either way.
Disco Stu III is offline   Reply With Quote
Old 02-11-2017, 11:56 PM   #4
That's a big tire. I've got them on my Wraith now. Haven't tried them on my Everest yet.
Old 02-25-2017, 07:51 PM   #5
Roll bar made out of a coat hanger
Old 02-25-2017, 09:35 PM   #6
Few questions for you. Just got an e10 and want to do the same. First, how did you decide how much to cut. Second, what did you use to secure along the cuts. Third, what is the black pad on the bed?
gibz117 is offline   Reply With Quote
Old 02-25-2017, 10:01 PM   #7
Start with a straight cut down the center, then overlap then to determine how much taper you want. After that, cut through both layers to make the seam match. I used drywall tape and GOOP epoxy to bond it back together. The black plate in the bed is Kydex.
Old 02-26-2017, 12:47 AM   #8
Thanks. I also narrowed a body, without the taper.
Old 03-02-2017, 11:39 AM   #9
Thanks guys.
Don't be afraid to cut it up, just cut a little at a time and use electrical tape to hold it together while you step back and take a look. If you cut too much, it might just make you see a different design to make.
A new body is only about $23.
Old 04-19-2017, 06:04 PM   #10
whats with the holes in it?
mooman is offline   Reply With Quote
Old 04-19-2017, 06:35 PM   #11
I cut them for another Everest I was building. The shocks and towers stuck through.
