01-19-2018, 01:12 PM | #1 |
Newbie Join Date: Jan 2018 Location: Cherryfield
| One wheel not spinning?
One of my rear wheels is slipping... rig is a hsp rgt 18000, same feat as exceed redact and other brand axles drive train etc. Also looking to get little more speed, battery best way to speed her up or is a new motor good way to go. Have lots of Dewalt drills sitting around was wondering about salvaging one of the motors from a 18v will it run of lower voltage. |
01-19-2018, 05:04 PM | #2 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
| Re: One wheel not spinning?
You could run from 3s up to 5s Lipo packs.
01-19-2018, 05:37 PM | #3 |
Quarry Creeper Join Date: Jan 2016 Location: Wichita
| Re: One wheel not spinning? |
01-19-2018, 05:38 PM | #4 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
Sounds look a plastic locker stripped out definitely upgrade the lockers before you power up.
01-19-2018, 05:39 PM | #5 |
Best way to speed it up is with a combo of motor and gearing. You've most likely striped the diff locker in the axle. That's why the wheel isn't spinning. Sent from my SAMSUNG-SM-G900A using Tapatalk |
01-19-2018, 05:44 PM | #6 |
Sorry guys, I forgot the ESC only support up to 3S. As the OP mentioned above the motor rated 18v, so I mean could be up to 5s Sent from my iPad using Tapatalk |
01-23-2018, 06:44 PM | #7 |
Was totally the locker, got new all metal ones on the way running 3 wheeled thing still impressive crawler. Also ordered LiPo battery 3s !!! That should kick up speed. |
04-27-2020, 10:38 PM | #8 |
Newbie Join Date: Apr 2020 Location: los angeles
I've got the same problem one of the rear wheels isnt spinning. What locker did you order?
One wheel not spinning? - Similar Threads | ||||
Left front wheel not spinning on V2 Axle... | i-5 | EnRoute Berg | 5 | 06-19-2011 08:09 AM |
Spinning rear motor - no spinning rear wheels | Sno Dawg | Redcat Crawlers | 13 | 04-24-2011 08:45 PM |
spinning wheel hexes | RnRJeep | HPI Wheely King | 21 | 10-02-2008 05:37 PM |
Spinning hub in wheel | JeremyH | Tamiya TLT Crawlers | 14 | 06-17-2006 04:40 PM |
