04-21-2019, 05:08 PM | #1 |
Newbie Join Date: Apr 2019 Location: US
| Steering issues need info
We recently purchased a sound box for my daughters redcat everest gen 7 pro. It was installed and now it'll go forward and backwards but the steering doesn't work at all. Any one have ideas of how to fix this issue where to get info for the issue?? Sent from my Pixel 2 using Tapatalk |
04-21-2019, 05:28 PM | #2 |
| Re: Steering issues need info
Did the steering work fine before? When you installed this sound box did you possibly unplug the steering servo? A picture of the wiring would help as we dont have much to go on with your description. |
04-21-2019, 05:31 PM | #3 |
Yes the steering was unhooked but put back and now nothing. still sound and forward and backwards Sent from my Pixel 2 using Tapatalk |
04-21-2019, 08:40 PM | #4 |
how dose the sound unit hook in dose it go between the esc and the reciver or dose it y in it could be the servo isent reciving enuff voltage to work right after you hooked the sound unit in might need a bec try swaping the chanels around and see if the servo works on the throtle channel andnor unhook the siund unit and try it again |
04-22-2019, 04:48 AM | #5 |
I wanna be Dave Join Date: Apr 2012 Location: Merrill, WI
Sounds like you may have broke the servo plugs. I would plug another servo in and see if that functions. Also check out the radio. The steering rate might have gotten turned down to low. I have had this happen from my kids playing with stuff while they are hanging out with me. Sent from my Vivo XI+ using Tapatalk |
Steering issues need info - Similar Threads | ||||
Steering issues | SitkaTundra | Axial AX10 2nd-gen | 5 | 02-20-2018 04:23 AM |
Steering issues | dasco | Axial XR10 | 3 | 10-25-2016 05:32 AM |
Steering info | Exocaged | Axial Wraith | 3 | 06-08-2014 05:33 AM |
Steering issues | Boids | RC4WD Bully | 39 | 03-15-2011 09:18 PM |
steering issues | wolfkings | General Crawlers | 3 | 03-05-2007 12:20 PM |
